e85 & nitrous mix?
Old Apr 20, 2015 | 09:31 PM
ponce7's Avatar
e85 & nitrous mix?
Im currently running a stage 2 gm kit. Full zzp bolt ons.
Gonna go on a 2.7 pulley and 80lbs injectors to run e85 and know id only be close to 300hp. I want a little extra so thinking of doing a 75 wet shot . i talked to a tuner and he told me it was not a good mixture .. He said id have fuel starvation ..
Anyone running e85 and nitrous ? Where are you guys pulling the fuel from? And what mixture are you guys doing
Old Apr 20, 2015 | 10:39 PM
Its a possible issue, as your car goes through e85 quite a bit faster than 93. Theres ways around it though if you got the pump for it and return style setup
Old Apr 20, 2015 | 10:53 PM
ponce7's Avatar
Ahhh i see... Kinda hard to decide what route to go. Everyone says go turbo but going turbo not so cheap lol im looking to be at around 350-400hp . if anythingg i posted my ss up for sale . and ill just go with an lnf . theres one here in phoenix for a killer deal .
Old Apr 21, 2015 | 01:52 AM
wayfarer's Avatar
I am on E85, M62 w/ 2.7, and have a 75 wet shot. However, I am at 6000 ft altitude, so my IDC was very low on 80's, so I had room.
I switched to Bosch 630cc, haven't tuned yet, so I don't know what my IDC is now. We'll see where it lands with and without spray
Old Apr 21, 2015 | 01:53 AM
ponce7's Avatar
And what numbers did you out down with that set up?
Old Apr 21, 2015 | 08:17 AM
Probably 330+, but low altitude is so key, and you sir, have low altitude.
Old Apr 21, 2015 | 08:28 AM
mrbelvedere's Avatar
you can run e85 with your juice and be fine do a 125 shot that should put you close 400 make suer you pull timing accordingly
the lnf is not the way to go they are more expensive to mod then a lsj
Old Apr 21, 2015 | 09:40 AM
yellowsupercharged06's Avatar
TVS with a 2.8 on E85 without nitrous will give you about 330-340 ish (speculating) ... cheaper than a turbo, there is a tvs for sale right now on FB for $1650
throw some nitrous at the tvs and hold on.
And that you can get to with the stock pump and 80's. Thats what im running right now.
Port the head and get some cams and you will have some more powwwaa
Old Apr 21, 2015 | 12:07 PM
Arent 630cc more like 60s?
Old Apr 21, 2015 | 01:33 PM
JapEatr's Avatar
South Central *********
im running a 100 wet from the rail, but I have a larger DW300 intank pump, RSFS, and surge tank with inline Bosch pump as well.
Also you will have to run different jet sizes for the fuel side, typically .003 larger
Old Apr 21, 2015 | 07:18 PM
wayfarer's Avatar
yes, 72lb @58psi
Old May 3, 2015 | 11:05 PM
Psykostevo's Avatar
I am pretty sure it was me that you were talking to.
What I am referring to is how the factory fuel rail tends to starve cylinders 3 and 4 as is if you use 60# or larger injectors. Now on top of the proposed 80# injectors you want to run a wet shot, which will also be pulling fuel from the same feed as the rest of the fuel system when it is activated.
I am very curious where this desire to run the e85 combo with nitrous is coming from.
Old May 3, 2015 | 11:08 PM
Psykostevo's Avatar
Carlos, this type of fuel system would work reliably with your desire for that e85 / nitro concept. Just don't do it on stock return less fuel rail and stock pump, etc.
It's good that you are doing your research on it first. I still advise against it since most LSJ are 10 year old engines at this point too.
Hugger1975
Oct 15, 2015 03:28 PM
Builttss
Oct 4, 2015 10:21 AM
TylerJHowell
Sep 21, 2015 06:47 PM
Macgyver2484
Sep 2, 2015 05:44 PM
