Eaton Superchargers Modification Guide
Old Feb 8, 2008 | 09:35 AM
XCRuna1201's Avatar
So how exactly would go about to plug up those 2 noise reducing holes?
Old Feb 8, 2008 | 09:44 AM
RuSSo-29's Avatar
Edubs > All! Bout time U put it over here man!
Old Feb 8, 2008 | 09:49 AM
SCBLKRL's Avatar
subscribed to read later
Old Feb 8, 2008 | 09:51 AM
Edubs's Avatar
There is an inherent risk with all methods of plugging those holes. Like suggested, contact professionals regarding your intentions and take their advice seriously.
There are people that have successfully plugged the leakage ports, whether they used JB Weld or had professional welding done, I don't know. Just remember that if there are complications with this modification, it could mean severe disaster...
Old Feb 8, 2008 | 10:06 AM
RuSSo-29's Avatar
That sounds like a job for, Du du du dunnnn MATT @ Tune Time!
Old Feb 8, 2008 | 10:10 AM
rukkee's Avatar
I wonder if someone would prefab pieces to weld into the leakage port's . That way you wouldnt have to worry about them as much , just weld around the outside of the case . It's not something that i would want to do just because i'd be paranoid about uneven heating and warpage.
Omega_5's Avatar
Before I mention how to do it from a mechanical design POV, I want to state that I don't recommend doing this at all.
If you can't metal weld it, or JB weld it.... there is only one thing you can do... Press it.
You'd have to press in an aluminum filler, and shave bottom flush again.
For ease of process, it would be beneficial to bore out the holes to be round first (as opposed to the stock oblong shape).
History has shown that a proper press job will not fall out, and will not affect the structural integrity of the part.
Old Feb 8, 2008 | 10:12 AM
SSdan's Avatar
I'm one who used JB Weld on my silencer slots. Thousands of miles later, no problems so far. I'm itching to pull it back off just to check on them, but i'll wait for a warmer date.
Old Feb 8, 2008 | 10:19 AM
RuSSo-29's Avatar
+ 1 on the confidance for me now that JB Wleding would be an ok way to go (With some one who knows what there doing)
Old Feb 8, 2008 | 10:47 AM
Rangerondubz's Avatar
How much louder did it get?
Old Feb 8, 2008 | 11:08 AM
  #36
RuSSo-29's Avatar
yes... how much
Old Feb 8, 2008 | 11:13 AM
  #37
OniMirage's Avatar
Originally Posted by RuSSo-29
yes... how much
x2...
Old Feb 8, 2008 | 11:15 AM
  #38
lsjwannabe's Avatar
go to svtpeformance, some of the cobra guys do it, and yes it is louder to the point you can tell a difference.
Old Feb 8, 2008 | 12:21 PM
  #39
RuSSo-29's Avatar
SAWEET! I'm having a Shop p&p my S/c... I'll talk to them about also filling in these holes
Old Feb 8, 2008 | 01:13 PM
  #40
phatnackySS's Avatar
i filled my holes..(that sounds dirty) passing people with there windows down has never been more fun. the scream dosnt seem louder just more high pitched and and is louder sooner.
Old Feb 8, 2008 | 02:27 PM
  #41
Edubs's Avatar
Sticky???
Old Feb 8, 2008 | 02:52 PM
  #42
Misery5567's Avatar
Tell me this (for those that know):
Is there a gasket of some sort between the SC and the motor? And if so, why can't one be cut/made
that blocks off those two port areas? Unless the holes are recessed up in the housing. That would shoot
this idea down.
But what about it? A gasket mod?
Old Feb 8, 2008 | 02:55 PM
  #43
TVS_SS's Avatar
this idea down.
Yes, the outlet port and backflow slots are recessed from the gasket surface.
Old Feb 8, 2008 | 02:56 PM
  #44
Misery5567's Avatar
I thought it was too easy of an idea
Old Feb 9, 2008 | 07:09 AM
  #45
SSdan's Avatar
The whine becomes apparent the second the bypass fully closes and the car begins using the boost, IE 1PSI. At that low of pressure, it isn't loud by any means, but you can surely hear it.
By the time I reach my full 18, the thing is screaming. First night I had it, went under an overpass with windows down WOT in 2nd and my ears were hurting.
Old Feb 11, 2008 | 08:34 AM
  #46
Edubs's Avatar
No love from the mods?
Old Feb 11, 2008 | 08:43 AM
  #47
Omega_5's Avatar
Send DC a PM...
Old Feb 11, 2008 | 08:53 AM
  #48
stavros's Avatar
for some reason it wont let me subscribe!!! tryin again.
Old Feb 11, 2008 | 09:20 AM
  #49
What did you use to fill yours up?
Old Feb 11, 2008 | 10:42 AM
  #50
rocco11189's Avatar
subscribed. maybe some pics?
