Effects of running lean
Old May 13, 2011 | 01:47 AM
Maupin SS/SC's Avatar
I lost to a 2.85 and 42# balt with h/e and hiflo cat and modded stock exhaust 3 times in a row by the same amount.
I'm 2.8 60#s catless, gmpp sport, dualpass, h/e
my afr was lean at 12.1 which i know is bad and if i had heat soak or was super lean how much would that effect the pull? we went from a 40 and he pulled before we shifted to 3rd so pls dont make driver error comments
FML
Old May 13, 2011 | 01:50 AM
Dr.Balt407's Avatar
to my knowledge running that lean will lead to a blown motor over time or on the nex wot. you want to keep your afrs in the 11's.
Old May 13, 2011 | 01:58 AM
ino that.......thats why im asking. i wont be doing any pulls or anything til its changed but thanks cpt obvious
Old May 13, 2011 | 02:01 AM
InfraRedline's Avatar
Meh 12.1 wont hurt anything on that setup. The car would probably like to be a little richer but as long as you arent knocking it would just be considered a little bit on the "aggressive" side.
Old May 13, 2011 | 02:05 AM
Dr.Balt407's Avatar
instead of acting like a smart ass just get your car fixed then. your the one asking a question you already kno......and ppl wonder why they dont get any responses in their threads.
Old May 13, 2011 | 02:09 AM
100% METH's Avatar
Exactly ^^^
OP,
Throw a 3gph water/meth nozzle pre blower w/ a 50/50 mix, should richen you to roughly 11.6-11.7 and crank the timing.
These cars don't make much power from fuel... its all in the boost (efficiency) and timing.
Old May 13, 2011 | 04:15 AM
87gn06gto07irl's Avatar
His tune>your tune.
Old May 13, 2011 | 10:40 AM
D_Rob's Avatar
Originally Posted by 87gn06gto07irl
His tune>your tune.
That's what I was wondering. And 12.xx is a bit sketch to me. Maybe 11.8. Is your IC pump good? What are your IAT's? If you know him and can I'd log both cars and compare.
Old May 13, 2011 | 10:41 AM
Chevycobaltss3's Avatar
yeah 12s arent bad as long as its not 12.5+ with no meth or e.
Old May 13, 2011 | 10:43 AM
BLAZIN07SS's Avatar
I'm too JDM for you
12.1 isn't dangerous. just aggressive as long as it's not knocking
Old May 13, 2011 | 04:19 PM
Hockeyman's Avatar
that tiny exhaust is probably holding you back, do you know your IAT2s? Timing? any knock?
Old May 13, 2011 | 04:54 PM
springerdesigner's Avatar
wanna run me..? good luck man.
Old May 13, 2011 | 05:28 PM
383_Stroker's Avatar
Those cars should be hella close together.. lol.. Maybe you just had more stuff in your trunk? :P
Old May 14, 2011 | 12:49 AM
insylem's Avatar
FML
WOW that first part is my setup, the 2.85 and the 42s... He must be cutting it close on his injectors like I am. I have plans this summer hopefully to upgrade to 60s. I want to do an exhaust and injector upgrade, that way I only have to pay for tuning once. I dont have the HE or any exhaust mods though.
Old May 14, 2011 | 02:44 AM
im told its my slammed car angle angle = tons of DT loss
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
