Electronic boost controler for the Eaton!
Old May 28, 2007 | 09:28 PM
Omega_5's Avatar
Uh-oh... gonna get flamed!
I doubt this would ever work for us...
Toyota has an electronic boost control system for the Eaton supercharger on their TURD SC'd Solara. Now listen up closely.... it isn't the kind of electronic boost control system that you see in turbo cars with the fancy blue screen and stuff. This is simply an boost sensor feeding information into the ECU and an electonic valve (in place of a pressure actuated valve) controlling the boost.
During that long incubation period, TRD decided to design the supercharger kit with an electronic boost controller--basically an electronic actuator for the standard Eaton bypass valve, which works like a wastegate, dumping boost at two critical points: one, between shifts and two, when the ECU goes into rev-limiter mode.
Here is the link:
http://www.sportcompactcarweb.com/fe...d_camry_solara
EDIT: Sorry for geting everyone hyped over the title... Just thought I should share... you know, like back in play school...
Old May 28, 2007 | 09:32 PM
cybcow's Avatar
I know you can control boost through hptuners so I don't see why you couldn't have such a device.
Old May 28, 2007 | 09:34 PM
widebody_balt_ss's Avatar
I am trying to learn how to control boost w/ hp tuners. i want to limit boost in first gear for the track.
Old May 28, 2007 | 09:56 PM
Area47's Avatar
Rent me! per hour
torque management - supercharger - max boost 1st gear.
100 = ***** out
70 is about 10 psi
50 is about 7-7.5
Old May 28, 2007 | 10:15 PM
yellowcobaltss05's Avatar
gotta love reduced boost in 1st
Old May 28, 2007 | 10:19 PM
Area47's Avatar
Rent me! per hour
people ask me what the hell the fluttering noise is when i hammer it in the first.
"uh, thats the bypass valve freaking out"
right about that time, i hit 2nd, and their heads hit the head rest
Old May 28, 2007 | 10:20 PM
nioce man noice!
Old May 28, 2007 | 11:36 PM
how far do u reduce boost? 50? i dont want to hurn my overall 1/4 times. just enough to make sure i dont brake the tires loose
Old May 29, 2007 | 12:02 AM
Delta2.2's Avatar
ok if u wanna limit boost do this. buddies use HPT for this its called a Boost Ram
have it
rpm start-3500 30%
rpm 3501-4000 90%
rpm 4001-max 100%
Old May 29, 2007 | 11:39 AM
Area47's Avatar
Rent me! per hour
mine is set at 70 all the way up.
the car makes peak power high up in the rpm band. either you can back it down up top, or keep it consistant.
mine still spin, but im not blowing the tires off on the street. it is something i can drive through
Old Aug 7, 2007 | 07:17 PM
Boosted07SSSC's Avatar
wait can we just use an mbc
Old Aug 7, 2007 | 07:26 PM
RedlineBrian's Avatar
That whole "Stage 3" kit for the Solara was $10k. For ~250 whp on 4 lbs. of boost. Stooopid money.
turbochargedss2012
Sep 20, 2023 12:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
Coballin13
Sep 25, 2015 08:43 AM
