emissions on a turbo swap
i am a ct state certified emissions tester, in ct if your check engine light is off and all your moniters are ready, and your car has been through its drive cycle it will pass. all the test is doing is looking for moniters and the inspector checks to make sure you have a cat installed on your exhaust. the put a wire to your OBD2 port to get the readings. If your check engine light is off you will pass, in ct lol
if your pcm is reading wrong due to an O2 move or MAF change then it will throw a code. bigger maf shouldnt not right away anyway. but if the O2 sensor is move to a wrong place it will shoot a code. pass first then do it
ThoR294
10-04-2015 08:44 PM
