Engine is apart, here is the damage...
Old Jul 2, 2010 | 12:40 PM
  #51
mrbelvedere's Avatar
bryan(area47) and darkmanx ran a 2.6 pulley on stock headstuds in the area of 28psi. i have only heard of one car stretching the head bolts and it was a redline that did it on the stock 3.1 inch tvs pulley
https://www.cobaltss.net/forums/advanced-performance-modifications-130/how-its-supposed-done-207331/
but he is using arp head studs now the reason why people pop an engine after forged slugs swap is either tuning or poor prep work
Old Jul 2, 2010 | 02:05 PM
  #52
Darkmanx's Avatar
Originally Posted by mrbelvedere
https://www.cobaltss.net/forums/showthread.php?t=207331
hes also using a stock head gasket and area doesnt race alot. even after i took my ported head off i re used my stock gasket and doged it 300 miles to go trade the car in and it was fine.
Old Jul 2, 2010 | 02:09 PM
  #53
DjJoeski87's Avatar
Then good as new
Old Jul 2, 2010 | 09:34 PM
  #54
rockSTAR_SS's Avatar
I think cylinder pressure has a lot to do with stock sleeves cracking also. Most of these guys running ported heads or TVS' or anything of the sort that will cause pressure to rise will be more prone to these types of problems.
Old Jul 2, 2010 | 09:41 PM
  #55
Frew's Avatar
I have the stock headgasket and arps on my ported head, I heard to many horror stories about the cometic, plus with people on stock block, head, studs, and headgasket pushing 28 psi both turbo and sc I would say the hg has earned its keep.
Old Jul 2, 2010 | 09:49 PM
  #56
ralliartist's Avatar
DING DING DING DING DING!!!!!!!
Old Jul 2, 2010 | 10:25 PM
  #57
lsjion's Avatar
I've personally pulled 3 apr to find stock head bolts loose. it was always said to be stretched bolts....hmmm
Old Jul 2, 2010 | 10:53 PM
  #58
MrSlickSter06SS's Avatar
Humm so whats the deal then? is cometic hg's the gaskets to use or not? because I wanna try to avoid this as much as possible for when I get my head ported...
Old Jul 2, 2010 | 10:55 PM
  #59
I'm a fan of the stock head gasket. It's MLS just like the cometic and it comes with copper spray already on it and some gasket material already made onto it. The cometic has no rubber gasket material and is not sprayed with copper so it doesn't seat as easily.
Old Jul 2, 2010 | 11:10 PM
  #60
lsjion's Avatar
I copper spray all head gaskets now, and since doing so, I have yet to have one leak on me.
Stock hg is suffice and cheaper
Old Jul 3, 2010 | 12:58 AM
  #61
the reason most people have problems with the cometic hg is they dont follow directions jordan aka tennpen ran a cometic for a long time until a oil ring went **** up and he is the only one i know of that has stretched the stock hb bad enough to cause a leak
same here ive pulled a few apart and found loose hb
Last edited by mrbelvedere; Jul 3, 2010 at 12:58 AM. Reason: Automerged Doublepost
Old Jul 3, 2010 | 12:44 PM
  #62
Cefaln452's Avatar
sleeves/the block have weak points, if the rings are not placed correctly in the correct area it causes extra stress and wears where it shouldn't be and when you have high compression along with that it blows a sleeve.
as far as the cometic goes... IF you install this right you have no problems..
as far as all the engine that are ******* up... that due to the fact of people don't know what the **** they are doing and have no business cracking open a block
Old Jul 3, 2010 | 01:33 PM
  #63
damien's Avatar
I dunno..I cracked mine open without any prior experience. Runs like a champ
Old Jul 3, 2010 | 01:54 PM
  #64
gotboost?17's Avatar
Nothin Stock
nice nice
Old Jul 3, 2010 | 02:15 PM
  #65
Lol Thats funny.
Old Jul 3, 2010 | 02:59 PM
  #66
Cefaln452's Avatar
luck.
Old Jul 3, 2010 | 03:27 PM
  #67
Piston rings only go on one way. Pretty hard to **** it up.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
