Engine Belt
Old Apr 25, 2006 | 03:12 PM
OUTPR4MZ's Avatar
Engine Belt
Moved to a 2.8" supercharger pulley, but need a new belt. I have tried every local store I can think of. Any ideas on where to get one??
Old Apr 25, 2006 | 04:39 PM
Nuclear's Avatar
try getting the part # for the gm stage 2 belt
Old Apr 25, 2006 | 04:45 PM
CTCOBALTSSS's Avatar
All you have to do is go to the link i'm putting in here and fill out the email form. GM will email you back the part #.
https://secure.gmpartsdirect.com/sec...tomer_service/
Old May 2, 2006 | 11:36 AM
OUTPR4MZ's Avatar
I Have Found A Alternative Instead Of Finding A Smaller Belt. I Used A 76mm 6 Groove Pulley From Dayco.. Worx Great With Zero Slip
Old May 2, 2006 | 05:36 PM
silverSS's Avatar
link?
Old May 2, 2006 | 09:14 PM
Jmc007's Avatar
http://www.zzperformance.com/cobalt_...290ed9c97ad417
Old May 3, 2006 | 12:57 AM
silverSS's Avatar
kinda wondering about the link for the belt.
thanks.
JMC, whats your opinion on that tensioner? will it hold a 2.5" pulley? How low will it hold?
Old May 3, 2006 | 10:22 AM
Knightrider22's Avatar
yeah i have a 2.8 pulley and i got the 3.0 idler pulley from Intense and it still slips...if i get the
Adjustable Tensioner will is get rid of the slip??? and is it hard to adjust?
Old May 3, 2006 | 06:36 PM
silverSS's Avatar
still slips wtf?
thats why im gonna wait for the Stage 2 belt here is the part # 12597993
go bug ur dealers!!!
Old May 3, 2006 | 06:39 PM
ENUFPWR's Avatar
I wasn't too hard... I'm running the ZZP tensioner and the 3 idler pully from Intense on my setup. I have a 2.6 pulley and have the setting on the tightest and no slippage.
The only thing the ZZP tensioner doesn't have is a place to put a wrench like the stock tensioner to adjust it. I had to push down on the tensioner really hard and hold it, while a friend slipped the belt on. It was a pain to get it on, but once done it removed all the slack and no more slipping belt.
Old May 3, 2006 | 06:42 PM
patathSS's Avatar
Your belt still slips?!??!!?!? Are you sure its not something else slipping, aka clutch. Because I haven't heard of any slippage with a 2.6" here and the 3" idler.
Old May 3, 2006 | 07:10 PM
ENUFPWR's Avatar
Pat,
Nope... not since I put the zzp and 3 inch idler I had no belt slippage. Clutch was a different story at the track. I need to break it in more. It was hard to determine and I only noticed it after I put the 2.6 on.
I know it was the belt because I would notice my boost would go down 1lb at 6000+rpm and noticed some knock retard on topend. I had a weak tensioner from the factory... had the stock belt slipping when I put a 2.8 on. After I installed the zzp tensioner, went back for another run and logged some more data.... the slippage was gone and 1lb of boost was back with zero knock retard on top.
Old May 3, 2006 | 08:47 PM
Jmc007's Avatar
The tensionner is great set at the tightest with the 2.6". If someone plan to go to a 2.5" sueprcharger pulley, maybe you will have to combine it to a bigger idler pulley to be sure the belt doesn't slip.
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
