Engine Flat Lining Under Hard Acceleration !!!
Old Oct 4, 2007 | 10:57 PM
RON's Avatar
RON
Exclamation Engine Flat Lining Under Hard Acceleration !!!
Hey Guys, Have Anyone Of You Had Any Trouble With Your 2.0 Shutting Down Under Hard Acceleration???
It Happened Tonight, And About A Week Ago , I Was Gettin Busy On The Gas Pedal And The Car Bucked And The Motor Shut Down Completly No Banging Noises, No Tack Signal Just Udder Silence And I Coasted To A Stop And The Car Didn`t Start Back Up !!!!
I Popped The Hood To A Look Under To See If Something Came Disconected Nothing, Waited 2 Minutes The Motor Started With The Cel On All The Way Home ! The Code Was A Po335 Crankshaft Position Sensor Circut Sensor (a)
Has Anyone Had Trouble With These Sensors Or Is This A First??? Please Help Me With Some Feedback !!!
STAGE 2 INSTALLED ABOUT 1200 MILES AGO, COULD DEALER BROKE THE SENSOR INSTALLING THE STAGE 2 KIT , OR THE SUPERCHARGER BELT?????
Old Oct 4, 2007 | 11:01 PM
SSdan's Avatar
It's the sensor. Known issue some people have.
Actually happened to me. Never got it fixed but it never came back either.
I was WOT in 2nd around 5500 when it happened.
Old Oct 4, 2007 | 11:03 PM
sensesfail99's Avatar
ditto
Old Oct 4, 2007 | 11:13 PM
suprchged's Avatar
same happened but when that happened it some hwo shorted out my cruise control and they had to replace my whole ecm.
Old Oct 4, 2007 | 11:19 PM
ItalianJoe1's Avatar
Yeah, I have been meaning to replace the CPS, its only $20 or so, but my car only did that shut-ff trick twice and the last time was over a year ago, so i'm not gonna worry about it.
Old Oct 4, 2007 | 11:40 PM
my cruise control effed up too, but i did the ol russian trick and gave it a swift hit and bang it works again!
Old Oct 4, 2007 | 11:45 PM
dbeausoleil57's Avatar
yeah my car shut off twice in the past 2 weeks
Old Oct 4, 2007 | 11:59 PM
stonny9's Avatar
Happen to me 1 1/2 yrs ago. Downshifted to second and went into limp mode. Sat a couple minutes and started it back up. Has been fine ever since then.
Old Oct 5, 2007 | 12:50 AM
do u have an intake david?
Old Oct 5, 2007 | 11:07 AM
firemanfrank's Avatar
I had posted about this problem a while ago.
My new '07 stopped dead when I only had like 1500 miles on the car. Took 10 minutes before it would start up again. Then a CEL lit up.
Went immediately to the dealer, and they put in a new crankshaft sensor - under warranty.
Don't mess around taking a chance peeps, if your car suddenly stops running for no reason, have the dealer check it out.
Get it fixed NOW ...
Old Oct 5, 2007 | 11:11 AM
JiggaChillan's Avatar
same thing happened to me, a few months ago. Crankshaft Sensor changed under warranty.
Old Oct 5, 2007 | 11:13 AM
efren6057's Avatar
x2!!
Old Oct 5, 2007 | 07:38 PM
RON's Avatar
RON
Talking Thanks For All The Info
I HAVE A APPOINTMENT ON MONDAY AT THE DEALER, CAN`T WAIT TO HEAR ALL THE CRAP I`M GOING TO GET ABOUT HOW IT`S NOT UNDER WARRANTY OR SOME CRAP LIKE THAT!
THE CAR HASN`T ACTED UP SINCE LAST NIGHT BUT LIKE YOU GUYS WERE SAYING SOME TIMES THEY DON`T ACT UP UNTIL IT DOESN`T START AGAIN!!!
THANKS FOR ALL THE REPLIES, OH SINCE MY STAGE 2 INSTALL I`VE INSTALLED A WEAPON-R COLD AIR INTAKE, HURST SHORT THROW SHIFTER, WEAPON-R RAM AIR KIT AND MODIFIED THE STOCK AIR BOX TO PROVIDE THE INTAKE OPENING THROUGH THE LOWER WHEEL SKIRT FOR THE RAM AIR BOX, AND JUST INSTALLED ZZ PERFORMANCE HIGH FLOW CAT 2.5 AND A COMPLETE MAGNAFLOW 2.5 INCH CAT BACK SYSTEM!!!!
DC SPORTS TOWER BRACE ECT. ECT. !
PEACE OUT DUDES!!
Old Oct 5, 2007 | 09:00 PM
mandk1229's Avatar
I sell cars for a GM dealer. My car did the same thing, I took it in and they replaced the sensor under the warranty. Seems like it is a national thing.
Old Oct 5, 2007 | 10:34 PM
Mikey851's Avatar
This is actually a common problem on many different makes and models of cars.
Old Oct 8, 2007 | 09:58 PM
killerbeecobalt's Avatar
I'm a gm tech if the cel came on at one time the code will be store as a history code. so if they check the info and see what happened at the time the light came on they should be able to fix it.
Old Oct 8, 2007 | 11:53 PM
ecotecon18s's Avatar
I'm next on the CPS list...getting mine replaced tomorrow...car was hiccuping really bad at WOT in 2nd gear...
Old Oct 11, 2007 | 02:12 AM
My car decided to shut off on the way home last night. I got a new sensor today, and $30 later i'm back in buisness. Woulda been a quick job, but I dropped the little bolt that holds the sensor behind the starter and it took forever to find it and get it out.
Old Oct 11, 2007 | 02:22 AM
xravenwingsx's Avatar
ItalianJoe...wow that sucks--glad you got it fixed though. Too bad that bolt was such a pain in the ass. :P
EDIT: has anyone done a howto on swapping out this sensor? I'm sure mine will inevitably fail, in time.
Old Oct 11, 2007 | 02:20 PM
Theres not much to it, just take a 10mm socket on a 6" extension, work it in there, remove the bolt, CAREFULLY grab the sensor with pliers and pull it out ( Maybe you can get it by hand, but not my big ass self). Unplug the old sensor, I re-taped the little wire harness because the ends were coming untaped.
Plug the new sensor it, put a little lithium grease on the o-ring and push it back into the block, try to align the bolt hole as much as possibe. I used a tiny screwdrive to center the holes, then use the bolt to tighten the sensor gently, hand tight plus one little pull. Done. The instructions called for a Crank Variaton Re-learn, but my CEL didn't even come on. Car started right up and has been running like a champ ever since.
As a helper for installing the bolt without dropping it, tape it into the socket. I used a little blue masking tape, around the top 1/4" of the threads and onto the socket, held it firm until I got it tight, then just pull the socket off at an angle to break the hold of the tape.
Last edited by ItalianJoe1; Oct 11, 2007 at 02:20 PM. Reason: Automerged Doublepost
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
