Engine noise!?
Old Jan 21, 2009 | 11:46 PM
jonnymerk's Avatar
Engine noise!?
Why does my car sound like there is stuff rattling around in the head? It's not obnoxious but the noise is noticable almost like a deisel engine? I have stage II with a 2.9. What causes this noise?
Old Jan 21, 2009 | 11:47 PM
Nussle's Avatar
timing chain..... maybe
Old Jan 21, 2009 | 11:50 PM
ItalianJoe1's Avatar
Probably a chain tensioner going bad.
Or, try this:
Pull the big allen plug from the front of the head. I had the top bolt for the fixed chain guide back out, made a nasty noise like that.
Old Jan 21, 2009 | 11:51 PM
Jkunzy1690's Avatar
what year is your car? if its mid 06 and early 07 and comes from passenger engine compartment...most likely timing chain tensioner. if it rattles at idle then goes away when u rev up, then comes back again- timing chain tensioner. get it fixed before it gets worse. crate engine depot has them for 50 bucks or so. GM had the wrong part randomly put on the assembly line during those years which is why it is failing
hope this helps
Old Jan 21, 2009 | 11:52 PM
Unforgiv3n's Avatar
mine has been doing the same thing, and it seems like it has progressively been getting worse..... I also have stage 2.
Jkunzy1690's Avatar
Or, try this:
pic of bolt please this is new stuff
Old Jan 21, 2009 | 11:53 PM
Jkunzy1690's Avatar
get the new tensioner before the chain stretches out and youl have to most likely get the whole assemble replaced.... iu tried bringing it in for warranty work but it would never make the sound for the dealer. also go to autozone and get RESTORE oil additive in the meantime- it works like a charm
jonnymerk's Avatar
That could make sense since I've noticed it shortly after putting the 2.9 on. Could it be that it just needs to be adjusted? And if so would I be tightening or loosening it?
Old Jan 21, 2009 | 11:54 PM
I got nothing, I sold that head
The big plug on the front of the head, right by the upper motor mount. 10mm allen key. Take it out, the bolt is right behind it. Try it and see, just a suggestion.
Jkunzy1690's Avatar
the timing chain tensioner will tension the chain itself i believer, you dont have to do anything correct me if im wrong
Old Jan 21, 2009 | 11:55 PM
Has nothing to do with the pulley, its the cam drive chain, inside the motor.
The tensioner is a large nut on the back of the head, like 30mm or something.
Jkunzy1690's Avatar
okie dokie- worth a shot
thanks
Old Jan 21, 2009 | 11:56 PM
Yes, its hydraulic based, it will maintain constant tension unless it goes bad (which makes that nasty rattle sound)
Old Jan 21, 2009 | 11:57 PM
jonnymerk's Avatar
Thanks Ill have to take a look when its light out. Sadly I'm in FL and I'm prob fairing better then most but I had window frost tonight lol.
Old Jan 21, 2009 | 11:58 PM
Jkunzy1690's Avatar
thats what i thought- its powerde by oil pressure? which is why restore may be an effective oil additive lubricant
Unforgiv3n's Avatar
i still have factory warranty, just waiting for the time to take it back in
Old Jan 22, 2009 | 12:00 AM
Yeah, its in the 40's down here already
Yeah, it has a spring to hold base tension, but oil pressure increases the tension, so it can keep up with higher RPM demands. Some of them lose the seal internally and collapse, or get stuck and can't increase tension. Then you get the rattle we all love so much.
Last edited by ItalianJoe1; Jan 22, 2009 at 12:00 AM. Reason: Automerged Doublepost
jonnymerk's Avatar
geez didn't think it would get as cold a little bit further south. Is it difficult to access this bolt?
Old Jan 22, 2009 | 12:01 AM
Jkunzy1690's Avatar
everytime i hear that rattle in public i rev it up....its so embarrasing- look like a ricer in the parking lot
Old Jan 22, 2009 | 12:05 AM
jonnymerk's Avatar
Crap I hope it doesnt need to be replaced, I hate taking my vehicle in to dealerships.
Old Jan 22, 2009 | 12:09 AM
Jkunzy1690's Avatar
im telling you lol it does! but its really not a big deal, just go in there and own them. find the TSB on here print it out, and giv em hell. this is a part you do not want to wait on
Old Jan 22, 2009 | 12:12 AM
jonnymerk's Avatar
fak! I wonder how long it would take and if they have to disassemble a lot to fix this if it is an issue.
Old Jan 22, 2009 | 12:13 AM
Jkunzy1690's Avatar
about 2 hours of work. they have to take off the valve cover, hold the cams, and change the tensioner- i believe that is it ( correct me if im wrong) it would be less of a headache to pay th 100 bucks and have a shop do it dealdership mechanics can be hard headed bastards
Old Jan 22, 2009 | 12:14 AM
Nope, its a really simple procedure. I could do it in about 10 minutes, you can get to it without opening up the motor at all really. You do have to take off the valve cover to release the set on the tensioner, but thats the harderst part.
Old Jan 22, 2009 | 12:16 AM
jonnymerk's Avatar
I don't have a mechanic so I'll let chevy take the fall. I haven't been given any grief as of yet with mine. We'll see how it goes I'll have to remeber to post back once it's solved ect..
