engine power reduced help
Old Apr 24, 2013 | 09:33 PM
matt88davis's Avatar
i was driving then my car went into engine power reduced. Took it to gm they said the fuel pump went out and fuse block blew. Any anwsers why?
Old Apr 24, 2013 | 09:47 PM
nhanson's Avatar
I would check that stuff before they work on it.
Old Apr 24, 2013 | 09:48 PM
i already took it there tey cat find out the problem
Old Apr 25, 2013 | 10:18 AM
Viceversa10's Avatar
Had this problem a while back on my 07, it ended up being the wire harness from the ECU. There was a shortage somewhere within it. Replaced it and havent had a problem since
Old Apr 25, 2013 | 10:57 AM
MrSlickSter06SS's Avatar
Check the fuel pump..
Old Apr 26, 2013 | 07:31 AM
where can i get the harnss and did you replace the fuse block?
Old Apr 26, 2013 | 10:51 AM
the shop i went to bought the harness, and yeah i replaced the fuse block
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
