Engine stalled @ 135MPH
Old Feb 18, 2008 | 03:15 PM
n8g's Avatar
n8g
Has this happened to anyone else? 4th gear run up to redline...about 140MPH. Leave it in gear and let your foot off the gas using the motor to slow the car. Then at 135MPH the car shuts off. I lost all my power steering and brakes. I pulled to the side. Car wouldn't start for about 30 seconds, then stumbled back to life. I drove away as the car was running a little rough at first. No problems since.
(This was on a closed track with nobody around.)
Old Feb 18, 2008 | 05:05 PM
ralliartist's Avatar
uhh, sounds like something bad happened. Don't know, never happened to me.
Old Feb 18, 2008 | 05:06 PM
rallyracer's Avatar
Nope, never happened to me.
Old Feb 18, 2008 | 05:08 PM
Herndon_High_SS's Avatar
Did your cel come on? Mine did that at about 100. Mine was just a throttle positioning sensor though.
Old Feb 18, 2008 | 05:11 PM
UmeNNis's Avatar
whoa scary... stall at 135 lol
firestorm's Avatar
your lucky your not dead. i bet you overheated, and pcm shut you down, there is a switch for that.
Old Feb 18, 2008 | 05:22 PM
invisible's Avatar
Off topic a little but may i ask why you sold your camaro???
Old Feb 18, 2008 | 05:26 PM
WSFrazier's Avatar
I've had my engine die for odd reasons before. I really wouldn't worry about it. These cars are goofy.
Old Feb 18, 2008 | 05:28 PM
Coblt ss super's Avatar
mine shut off at 120 once, i noticed my knee hit the key and turned it off, could you have done that?
Old Feb 18, 2008 | 05:56 PM
n8g's Avatar
n8g
I didn't hit the key at all. No CEL either. I assumed that because I was still in gear letting the motor slow the car, it was starved for fuel, so it shut off. It was at ~5000 RPMs.
I sold the Camaro to try something a little different. It's easy to go fast in an F-body. A little more challanging to do it in a FWD 4 banger.
Old Feb 18, 2008 | 06:02 PM
a little more is an understatement. on top of that, you picked a supercharged fwd 4 cyl. Well, you an me both. It was easy to go fast in my dsm too.
Old Feb 18, 2008 | 06:04 PM
Onyxd04Redline's Avatar
What's wrong with cheap and easy speed? You always went to Fwd.
turbochargedss2012
Sep 20, 2023 12:17 PM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
