Engine whistling?
Old Jun 8, 2011 | 11:35 AM
smitzk01's Avatar
Engine whistling?
I installed dual pass yesterday. After I got it all back together and I started it up, then pressed on the gas, the engine started to whistle. I was trying to locate where it is coming from and it seems to be coming from near the intake manifold. I drove it around the block and it quit, didn't have any more noises all night. This morning I started it up and drove it a little and as I parked I noticed it was back. What could be causing a high pitch whistling noise? It has never done this before, I would say a gasket but why did it quit until morning? It has been around 96F. I still need to locate exactly where it is coming from but it is rather loud, so it is making it hard to locate. Any ideas?
Old Jun 9, 2011 | 05:52 AM
smitzk01's Avatar
I found it. It is coming from the intake mani gasket. Time to take off the blower and tighten down the bolts again just to see if it works. Got a new gasket on the way just in case.
Old Jun 9, 2011 | 08:06 AM
07BoostedG5's Avatar
You could spray the gasket with copper gasket spray, it fills imperfections in the gasket. Fixed my exhuast leak with this stuff.
Old Jun 9, 2011 | 05:36 PM
smitzk01's Avatar
eh I just ordered an extra gasket. I may not need it, I need to torque the bolts to spec. I am gonna get ahold of a torque wrench tomorrow and try that, if that doesn't work take the mani back off and put the new gasket on. only thing that sucks is I will have to drain the s/c coolant again after 3 days.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
