Exhaust downpipe/header gasket help
Old May 24, 2013 | 09:50 AM
punksk8ter62's Avatar
I keep having to buy exhaust downpipe gaskets because they keep blowing out. Does anyone know where I can get one that will be reliable?
Old May 24, 2013 | 09:51 AM
Staged07SS's Avatar
Administrator
Administrator
Stock is best, but Remflex makes a nice gasket as well.
Old May 24, 2013 | 09:54 AM
Thanks. I haven't even thought to try the stock one to be honest.
Old May 24, 2013 | 09:55 AM
Staged07SS's Avatar
Administrator
Administrator
I have a stock one if you need it.
Old May 24, 2013 | 11:35 AM
mrbelvedere's Avatar
ever thought the flange was bent
Old May 24, 2013 | 12:24 PM
TStone's Avatar
There's no reason to continually blow exhaust gaskets
Old May 24, 2013 | 12:36 PM
Gelladuga69's Avatar
Never had a leak with stock gaskets. A little pricey from the dealer, but it works.
Old May 24, 2013 | 01:00 PM
CordiaDOHC's Avatar
My dealer ones have always worked great. Except for when my flange was warped.
Old May 24, 2013 | 01:04 PM
Mr.Tozzi's Avatar
The stock gasket is by far the best option. Or just find one that has a steel ring around the inner part.
I believe I got my last one from napa but I don't remember the brand.
Old May 24, 2013 | 01:16 PM
nhanson's Avatar
Sounds like its either not tight enough or flange is bent/warped.
Old May 24, 2013 | 04:41 PM
Definitely not bent. I think the crappy paper gaskets I keep buying just aren't holding up to the extra flow from not being stock. I'm gonna buy an oem one and see how it does.
Old May 24, 2013 | 04:45 PM
Btw it's a bad mab header and a 2.5" cat less dp from zzp.
Old May 24, 2013 | 04:46 PM
xxenjoi11's Avatar
oem or bust, zzp maybe as well
Old May 24, 2013 | 04:55 PM
Fen52690's Avatar
when i bought my dp zzp's gasket burnt on me i bought one from napa and it was 10x better and thicker thats your best bet
Old May 24, 2013 | 11:23 PM
lmaorotf
Old May 24, 2013 | 11:27 PM
SalvageBaltSS's Avatar
im gonna be putting my badmab and zzp downpipe on here pretty soon, should I go buy new gaskets from napa? ( I have new gaskets that came with header)
Old May 25, 2013 | 01:43 AM
Seebs's Avatar
Personally, I welded my downpipe to the catback so I wouldn't have to deal with this issue.
Old May 25, 2013 | 02:20 AM
K-Train04RL's Avatar
Oem fits and works best. Had am one and didn't hold up well. Oem or bust
Old May 28, 2013 | 07:19 AM
Staged07SS's Avatar
Administrator
Administrator
Don't use the gaskets that came with that header. They are garbage.
Old May 28, 2013 | 11:48 AM
100% METH's Avatar
Remflex
Never worry about it again
Old May 29, 2013 | 07:49 PM
dtabbs's Avatar
Originally Posted by 100% METH
Remflex
If you do get Remflex, (I like them also) be sure and follow the torque spec and handling procedures.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
