option b question
option b question
I recently bought an option b from a guy on here. All i got was the tank and the bracket. So i have been searching for all the plumbing: hoses, clamps, etc, etc. I just want to be sure i have the right fittings as well
Brass 1/4" barb to 1/8" npt fitting
Airbleed restrictor fitting
I am having trouble finding the above fittings. I found an elbow brass fitting but i cannot find he airbleed restrictor fitting anywhere. I bought what looks like one of those fittings but i dont think that is the correct airbleed fitting. Not sure how to post pics of this but if someone can take a picture of it(airbleed fitting) and post it would be very helpful. I know that zzp and ottp has pictures of this but they are very small. Want a close up of it if possible.
How i wound up routing it
Opt b big line going through that opening in that bumper support
Oem bent hoses used to make a smooth kink free flow, put into y fittings
This is what you need for the orffice. Just go down to your Auto Zone or Advance or Checkers or whatever you shop at and pick up a universal vacuum Tee. Cut off with a razor one nipple at the size it will fit inside the bleed hose. It should fit in there snug and if inserted on the heat exchanger side it could never work its way all the way up to the surge tank.
Consider hand held.
Consider hand held.
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
