Exhaust leak
Old 02-27-2012, 10:17 AM
Blinker fluid's Avatar
Exhaust leak
Hey guys, just got my tsudo catback all zipped up...after a day or so the connection between the stock dp and the tsudo catback piece created an exhaust leak...When its cold you can see the exhaust leaking from this location, also created a farty sputtering sound which sounds terrible. The bolts are tight and the gasket is in there...what would I need to do to seal the leak?? Thanks for info
Old 02-27-2012, 10:21 AM
wwalker85's Avatar
Did you reuse the gasket or put in a new one?
Old 02-27-2012, 10:24 AM
reused, I bought the catback used online
could I get a new gasket from the auto store, if thats what I need?
Old 02-27-2012, 10:26 AM
Administrator
Administrator
Staged07SS's Avatar
Pick up a Remflex 2-bolt flange gasket.
Best move I made on my car.
I always had a leak there with my aftermarket setups.
Old 02-27-2012, 10:34 AM
Thankyou!!!!
Old 02-27-2012, 10:41 AM
I cant find them on oriellys, autozone, or napa's website. available only instore?
Old 02-27-2012, 10:53 AM
Administrator
Administrator
Staged07SS's Avatar
You need to order them online.
Go to Remflex.com
Old 02-27-2012, 10:54 AM
ok, thankyou sir.
Old 02-27-2012, 10:58 AM
Administrator
Administrator
Staged07SS's Avatar
ok, thankyou sir.
No problem.
Let me know if you need help finding the correct gasket.
Old 07-02-2012, 06:56 PM
blackdew21's Avatar
I hate to bring this back alive but I can't seem to find the the right gaskets for the lsj now..
Old 07-02-2012, 10:06 PM
Window Licker
sjc0013's Avatar
Remflex is the way to go, finally put mine on. Blackdew I'm not sure what exhaust/dp setup you have but what I did was get under my car and measured the bolt spacing on them and then ordered the right gasket
Old 07-02-2012, 10:12 PM
ssyellow's Avatar
Orange high temp silicone RTV=done.
Old 07-02-2012, 10:33 PM
Might pick up a remflex myself
Old 07-02-2012, 11:10 PM
^ took nate's advice and used a sheit ton of this
Old 07-03-2012, 07:12 AM
Administrator
Administrator
Staged07SS's Avatar
Do it man!!
01-12-2016 12:01 AM
hacadacalopolis
10-28-2015 06:09 PM
biniecki
10-25-2015 02:23 PM
brandon04
10-21-2015 07:04 AM
tomj77
10-04-2015 11:39 AM
Quick Reply: Exhaust leak
