Exhaust Question
Old Dec 11, 2008 | 08:36 AM
blazinbaltss's Avatar
Exhaust Question
would straight 2.5 exhaust be good for my cobalt like custom pipe from the stock manifold back? Because he says he wont be abe to bend the three inch on a cobalt so im just seeing. An do you think i will notice a lttle bit of horsepower diference from the stock exhaust
Old Dec 11, 2008 | 08:43 AM
qwikredline's Avatar
the difference between 2.5 and 3 inch in Grand Am competition when the 3 inch exhaust was taken away by the rules makers, was negligible. If you have really small pulley and a lot of mods it will make a difference, but for you , stock exhaust manifold I would go ahead with 2.5 and be happy, make sure you go to 3 inch at the rear most muffler if you can for the straight parts...good luck...
Old Dec 11, 2008 | 10:07 AM
ShortStack's Avatar
1.. Is it mandrel bent? If not, its pointless... The metal will be a smaller diameter at the bends causing flow issues..
2. If its not mandrel.. http://www.mandrelexhaustsystems.com...GNAFLOW/Detail <---comes with muffler as well for 255
3. if you want 3" - http://www.mandrelexhaustsystems.com...alt/Categories <-- You can pick with or without muffler.
Unless your around 300hp, or over, its been stated that youll actually lose power with the 3" exhaust.
with your setup, i think your close, but with the stock manifold, id only go with a 2.5", that will get you your best gains.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
