Exhaust smell(zzp header and downpipe catless)
Old May 9, 2008 | 09:41 PM
SnappyChevy's Avatar
Ive had my header on now for 2 months. An i still get a bit of a soft burning smell coming from the car. I really cant tell if it comes from under the car or from under the hood. Im pretty sure i dont have an exhaust leak on the header since i dont hear your typical tick tick tick sound from a leaking header. Now honestly i never put the heat shield back on after the install since it was driving me crazy to get it back on. Could that have something to do with it. This smell is really driving me nuts.
Old May 9, 2008 | 09:42 PM
silentd's Avatar
ive had mine for about 2-3 weeks.. same issue.
ticking does not mean a leaking header. and i have a the heat shield on
Old May 9, 2008 | 10:40 PM
Red Rocket SS's Avatar
Same issue here. Does yours kinda smell like burning plastic?
Old May 10, 2008 | 09:56 AM
brett5's Avatar
well if you have a catless down pipe that smell is all the emissions escaping. the cat is there to heat up the air coming out of the engine and to burn off extra fumes coming out into the air so say yousr engine is pushing out air at 300 degrees and it hits the cat it now heats up even more lets say 400 degrees to burn all the emissions up so when you take that out its pure emissions your smelling what a car should smell like go to any track and tell me you don't smell the same thing.
any car with no cat will smell like that and since our cars run rich to begin with we really notice it...question tho do you guys have trouble passing emissions where your at..if you have emissions?
Old May 10, 2008 | 11:44 AM
RollOver360's Avatar
I have had mine on for a couple months also, but I have only put a few hundred miles on it and it still has a burning smell. I just assumed its the ceramic coating.
Old May 10, 2008 | 11:48 AM
brett5's Avatar
no that smell won't ever go away any car without a cat or even with a high flow cat...that smell is what the goverment dosen't want pollutting our air..so in those regards i took mine out
Old May 11, 2008 | 01:32 AM
zero2redline's Avatar
yeah i got that same smell, its the high temp paint burning off
Old May 11, 2008 | 01:48 AM
springerdesigner's Avatar
same smell w/ high flow cat and black temp paint...
RaginChopsuey
Oct 27, 2015 01:27 PM
nathan112i
Sep 30, 2015 07:12 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
