a/f gauge
Old Jul 14, 2006 | 09:31 PM
distillion's Avatar
a/f gauge
where are you guys getting these gauges for yer car and where are you mounting them?, i have an 06 and goin in for a tune soon, and im interested in purchasing one.
Old Jul 14, 2006 | 10:39 PM
soccer1061287's Avatar
I have the autometer cobalt series a/f gauge and it along with an autometer cobalt series dpic gauge is mounted in a Perrin universal gauge pod that is mounted to the steering column. It mounts really well and the wires hide between the column and the IP trim easily. Only issue is that you have to look around it to see what temp it is outside or anything else in that little window. Not an issue for me. There is a picture of it in my vbGarage.
Old Jul 14, 2006 | 11:01 PM
Waylin22's Avatar
Found these 2 guages on ebay....the OBX one im not sure of...dont really know the brand too well so i think im gonna buy the cobalt one rite now
http://cgi.ebay.com/ebaymotors/OBX-U...07213051QQrdZ1
http://cgi.ebay.com/ebaymotors/AUTOM...07589952QQrdZ1
Old Jul 15, 2006 | 08:37 AM
distillion's Avatar
is there anywhere else i can get the cobalt gauges other than ebay?
Old Jul 15, 2006 | 08:53 AM
patathSS's Avatar
Keep in mind this is a narrowband, oscillating gauge that has no physical number output. It simply as an led bar that oscillates back and forth. Not very useful for tuning.
Old Jul 15, 2006 | 09:31 AM
distillion's Avatar
so wats a good gauge for tuning then?
Old Jul 15, 2006 | 10:01 AM
kanabrewski's Avatar
wideband, will have to have a bung welded in for it, but will give you the tuning numbers you need
Old Jul 15, 2006 | 01:03 PM
distillion's Avatar
where do i get this ?
Old Jul 15, 2006 | 02:41 PM
SpecialK's Avatar
At the Dyno shop if you can. They'll have the welder you'l need. UNless you have a Mig or Tig welder there at your house. All it is honestly is drilling a hole then welding in a bung. After that you just thread in the sensor adn run the wires through the firewall opening. Simple stuff.
Though the hardest part honestly is finding out where to mount it.
Old Jul 15, 2006 | 05:22 PM
player_1's Avatar
what about using the AEM UEGO Wideband or the LC-1 and relacing the stock narrow band location. they're supposed to operate at .1V so it doesn't confuse the computer.
at least that is the impression I was given.
Old Jul 15, 2006 | 06:16 PM
patathSS's Avatar
You can. I know the lc-1 has a second output preconfigured to simulate a narrowband output. So you just wire that into your stock harness. One bad thing is that the cat tends to give a leaner reading than actual so it can make a difference since the 2nd O2 sensor is post Cat.
AND if you are tuning or have been tuned with HPTuners, I would simply turn the CEL for the rear O2 sensor off and plug the wideband sensor in; much easier.
Old Jul 15, 2006 | 06:23 PM
JCswoosher2's Avatar
see i want to install mine but im scared of what i will get into.
Old Jul 15, 2006 | 06:33 PM
Cobalt_Supercharged's Avatar
I'm looking at getting HP Tuners. What Wideband do I need for that? I figured I would just weld in a bung into the down pipe before the cat.
Old Jul 16, 2006 | 02:21 AM
rob561's Avatar
any wideband will do
Old Jul 16, 2006 | 02:26 AM
Aeain's Avatar
Def. get an Innovate LC-1 with a Interceptor.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
