Few questions. Please help
Old Aug 3, 2010 | 07:37 PM
VERTZX's Avatar
Hey Css.net. I have a cobalt ss with a gm stage 2 it has intake and exhaust. I recently purchased a 2.8 2 step colder plugs zzp s3 he and 60 injectors. I plan on having a custom Dyno tune done. Is it possible o tune the PCM? I heard something about a lock on it. If I can't have it tuned what should I do? Please help, thankss
Old Aug 3, 2010 | 07:57 PM
stonny9's Avatar
yes you can tune it with hptuners but it cost 2 credits/$100 to unlock it plus what ever the tuner charges. The gm stage 3 computer is locked and untunable.
Old Aug 3, 2010 | 08:58 PM
VERTZX's Avatar
Thanks.
Also, if I put all of thsmese parts on will it run enough to get it to the tuner?
Old Aug 3, 2010 | 09:01 PM
Render2009's Avatar
I'm sure it will be fine but u have to stay outta boost
Old Aug 3, 2010 | 09:16 PM
VERTZX's Avatar
what do u mean?
Old Aug 3, 2010 | 10:05 PM
stonny9's Avatar
Originally Posted by VERTZX
Thanks.
yes you can but stay out of boost cause the injectors will be too big. make sure you drive straight to the tuner that isnt an hour away. I changed my injectors in a parking lot with simple hand tools. I can also change my pulley with an allen key and a chisel.
Old Aug 3, 2010 | 10:09 PM
rnjmur's Avatar
The car is going to run like absolute crap if you drive on 60# injectors without a tune. It may even hardly run. It is better to install the injectors when you are getting the tune.
Also, the stage 3 PCM can be tuned as well as the stock PCM.
Old Aug 3, 2010 | 10:10 PM
SilverSS_TNR's Avatar
yeah def shift at like 1200 and dont get on it at all on the way to the tune shop, if you can trailer it to be safe, or just put it on at the tuner shop.
Old Aug 3, 2010 | 10:40 PM
VERTZX's Avatar
OHHH okay, i thought he meant not to boost when i get everything done lol. im like then whats the point of the 2.8!? im prety sure theres a reputable tuner that comes to your house.. idk, kinda wanted a dyno tune though. i have to look around.
Alex47
Nov 19, 2021 08:24 AM
Turbo6
Aug 27, 2015 08:37 PM
CTCOBALTSSS
Nov 10, 2006 04:54 AM
PpAzZ1101
Mar 29, 2006 04:25 PM
