A few quick (simple) questions....
Old Sep 13, 2011 | 06:16 AM
supajut's Avatar
I have been amassing parts for smaller pulley and injector swap. Car is currently tuned (by me via HPTuners) and has Magnaflow CB and Injecn CAI. I understand with certain mods I will need cooling/exhaust upgrades, not asking about that.
1. When is it time to upgrade fuel pump? I have 60LB injectors...
2. When is it time to tune VE, I have a 3.0, 2.8 and 2.6 pulleys...
I realize I just need to load a stage 2 tune with the 3.0, anyone run that tune with the 2.8 or 2.6? Thanks for any and all help!!!
Old Sep 13, 2011 | 11:26 AM
Boosted05's Avatar
You will be lean if you run the S2 tune on anything other than that 3.0. Our cars can handle 400whp on the stock pump, and you could run E with 80's on it if you wanted. The 2.8 or 2.6 would require diff tunes to run properly.
Old Sep 13, 2011 | 03:19 PM
supajut's Avatar
Thanks!!! Aside from full out wideband tuning where would one find a 2.8 or 2.6 tune?
Old Sep 13, 2011 | 03:34 PM
Staged07SS's Avatar
Administrator
Administrator
That is not 100% correct.
You can actually become rich, because the PCM will try and cmnd the same 10.8 AFR of the GMS2 tune when it senses the increased airflow from smaller pulleys. The injectors will become static and just dump fuel once they loose control, because the PCM is trying to maintain the rich AFR of the GMS2 tune.
You would spike lean for sure on a redic small pulley if you tried running it on the GM tune & 42's though.
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Tdubbs
Oct 13, 2015 02:31 PM
toledobalt
Sep 2, 2015 01:19 PM
