fidanza flywheel
fidanza flywheel
are these things worth it and is this a good price?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...DME:L:RTQ:CA:1
We had a big discussion ot this subject a couple days ago https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/fidanza-light-weight-flywheel-40895/ read this forum. Also Scott the at WWW.CobaltPerformanceParts.com is starting a Group Buy on them so send him a PM that you want in if you plane on getting one, most likely you can get it alot cheaper.
The flywheels are perfectly balanced. I had one on my old cavalier, and I have 3 other friends that have them on their cars, never had a problem with rattling, or worping of the crank for that matter. The are real good for low end power, and a smart idea if your swapping clutches.
Keep in mind that if you are using this as your daily driver, you might find engaging the clutch slightly more of a pain in the ass for everyday use. It's nothing you can't get used to, but it's like getting a performance clutch in the sense that stop and go sucks a little more because of a more picky engaging point.
