Finally 13s!!!!!!!!!!!!!!!!!!!!!!!!!!...... :)
All the posts were about: He could hit this time, or that time etc... and then RT was mentioned, which doesn't matter. Thats why I said what I did..
I did not say it to dismiss the RT he did get, because it was a very good one.. So I just want to be clear I wasn't trying to be an ass that's all...
Edit: See now the post above this one, THATS being an ass lol
You said it yourself a couple of weeks ago
edit: and it's funny... CSS.net will call it stage 2 when it serves their purposes, but when it doesn't, they'll say it really doesn't count as stage 2... it's priceless the way this place works
it's the big elephant in the room everybody ignores
Some things that will be on for next year
Drag Radials
Exedy Clutch
DSS Axles
Tein or KW V2s
The WOT box
DEI Cry02 System
With these things 12s should come with ease
Drag Radials
Exedy Clutch
DSS Axles
Tein or KW V2s
The WOT box
DEI Cry02 System
i sure as hell hope 12's are on the way lol
this next thing is not directed at you, but this site in general:
since day one 90% of the people on here were concerned with one thing in order to make their cars "faster" and that one thing was power. this thread is as good of an example as you can get on here. you drive a fwd car that makes a decent amount of power, you need to modify for traction first and foremost, unless you enjoy getting smoked by pretty much anything else at a drag strip.
Track is a different game than the street, having more power sometimes hurts you even more which is the problem im running into, its hard to be fast when your spinning.
Theres no doubt I'd smash any stage 2 car from a roll on the highway but thats not my style or where I'm trying to get to.
I dunno how does it compare I did 80-100 in 2.7 seconds, you make the call
Yea your trap speed is way too low with the TVS i would look for a new tuner. When i went to the track i was spinning half way down the track and i still layed down a 105mph trap on the stock blower. with dual pass as my only cooling mod.
Goodjob man , glad to see you getting better just keep tweaking.
no offense, there might be a post I'm missing about tuning issues you're having or something. But why was your goal to hit the 13's?
and how did you only hit 13.9? Aren't you one of the guys with a blower swap? You've wasted your money if that's the case. I don't have meth and I hit a 13.9 on (i'm told) a slow track, with a 2.9" pulley, exhaust and intake.
Chris SS/SC, I hit 106mph on the run I just mentioned. I'm not a 13.3 car. With traction, a new clutch, and the header/dp and tune that I have now I'll be lucky to hit 13.5.
you shouldn't be shifting to 4th unless you have like a 20" tall tire or a 4.70 final drive.
You just don't trap high enough to warrant the shift.
thanks for the compliment. lol. I think my trap speed may be misleading though. That was on 26"x10.5" mickey thompsons. They are HUGE tires. They are great for traction and have a lot of cushion to help prevent breaking something, but unfortunately, they will extend the gearing of the car out quite a bit, and cause the car to fall out of the powerband when shifting to the next gear. For instance, I've raced a few friends on them from a 40 roll, I used 2nd and 3rd only, up to about 130ish and they used 2-3-4-5th gears.
I'm going to be using 24.9x8" hoosier's next season. I'm pretty sure I should come out of the gates with the whole new slip. It probably will look like I did quite a bit of stuff to the car, but in reality, I just properly sized the wheels and tires to the power level and gearing.
False. Just look at ralliartist. 13.2 @ 104. Just the fact that the trap speed is 106 makes the car capable of at least a low 13 second pass. You're telling me that with slicks and header / dp along with all of your other mods as well as a 1.9 or even a 2.0 60ft would mak you run a 13.5 if lucky? That is impossible-- unless your driver mod (or lack of mod) is that horrible.
Last edited by ralliartist; Oct 24, 2008 at 01:43 AM. Reason: Automerged Doublepost
unless your trap speed significantly increases, I don't see you hitting 12's. Make sure you get probably sized drag radials though, that could be all you need.
so if im at 7000 rpm in 3rd and im still 100 or so feet from the line I shouldnt shift? the top of 3rd is about 106, keep in mind also the redline wheels are a half inch shorter in diameter.
On this pass I hit the rev limiter and let off the gas totally then shifted into 4th, basically coasted across the line. I'd like to see some of you let off 100 ft before the line and still trap that high
Seriously you guys say some pretty dumb things but thats tops
Check your own data logs can any of the rest of you hit 80-100 in 2.7 sec? I had another stage 2 car compare it last night that runs 13.6s and he was seconds off that mark
