FINALLY! The answer to our clutch woes!
Old Aug 31, 2006 | 04:28 PM
  #151
Torque Junky06
Guest
Posts: n/a
Originally Posted by SSinPhilly
I just got back from GM and my car is going in Wensday for 2 TSB. 1. to fix my idle jumping problem and 2. the clutch slippage.
They told me they did 2 already and it wont be a problem. PLEASE GET THIS CHECKED OUT BEFORE YOU REPLACE YOUR CLUTCH.
Northeast Chevrolet
i had the number 1 problem before and then i got my stage 2 installed and that seemed to eliminate that idle jump. i guess cause when they put the stage 2 in, the flash increased my idle speed
Old Aug 31, 2006 | 09:57 PM
  #152
cds00bsmg's Avatar
Im more interested in this Corvette IIRC master cylinder possability.....
Above6k, thanks for the info. Its appreciated.
Old Aug 31, 2006 | 11:19 PM
  #153
OBSSSD's Avatar
Thanks for the info 6k. Just ignore the kids in here and you'll be a-ok
Old Sep 4, 2006 | 03:39 AM
  #154
Mike's SS's Avatar
If I remember correctly, in the gm build book the cobalt race cars (not drag cars) used a grand am or g6 master cylinder. Someone may want to try this, you can get the build guide online for free from gmtunersource.com.
Old Sep 4, 2006 | 03:46 AM
  #155
CobaltSS422's Avatar
No offense but I still think some of u guys are giving the car gas before you let off on the clutch causing it to slip and that is a very good way to ruin the clutch. I have 22k miles on my car and still on the stock clutch with no problems.. And i would call myself a free spirited driver and i believe the car calls for 32psi cold tire pressure.. check your driver side door
Old Sep 4, 2006 | 11:27 AM
  #156
USMCFieldMP's Avatar
Rattlesnake Race Shop
I'll check my build book and let you guys know shortly!
Old Sep 4, 2006 | 11:42 AM
  #157
Hate to tell you guys, but the GRAND AM CUP (ST CLASS) RACING SERIES Cobalt... it uses the stock master cylinder... and the stock Clutch. The only thing they change about the transmission is the final drive, which doesn't help any of us. I'll check the whole Build Book and see what HP they recommend changing the clutch and/or Master Cylinder... Part Numbers... so on, so on.
Old Sep 4, 2006 | 11:56 AM
  #158
Nothing.
Old Sep 4, 2006 | 09:47 PM
  #159
doz's Avatar
doz
Well, that guy got back to me. He said theres no TSB at the moment however he said something is being done about it right now.
To the guy who said people cant shift properly (a few posts up), the tech admitted there are problems with the clutches, and if not fixed, the clutches go QUICK. He said hell let me know when a fix is available though.
Old Sep 5, 2006 | 09:47 AM
  #160
cawpin's Avatar
Originally Posted by victory_red_SS
My friend who, helped me take out my engine, is a mechanic and he says bleeding Chevy clutches are a bigger pain than replacing the clutch itself. He said that he has had clutches where he spent 3-4 hours bleeding them until they were completely bled.
It isn't THAT much of a pain. I've bled a clutch before. While it is more sensative thatn brakes it isn't the end of the world. You just get a lot of practice pressing that pedal.
Old Sep 8, 2006 | 02:15 PM
  #161
Harley's Avatar
Could you post a name, number, and location of the dealer you got this fixed at. Several people have asked and it would be nice to know of a dealer nearby that would help.
Old Sep 25, 2006 | 09:08 PM
  #162
Floridas Finest SS's Avatar
updates?
Old Sep 29, 2006 | 08:48 PM
  #163
06cobaltls's Avatar
Originally Posted by an0malous
I think hes reffering to the fact that there are a few slight things a driver can do that will actually cause clutch slip even if everything is working fine.
IE these cars have a very short first gear....which is very capable of breaking loose at ANY point in the rpms.
due to this fact ALOT of heavy launch shifting from first to second, results in a shift into second gear, when first gear hasnt properly been utilised.
Think of it this way.
say your car is geared to do X MPH at the top of 1st gear.
If you spin/hop heavily and your cars speedometer reaches X MPH, you will shift to second. but unfortunately your car isnt really doing X MPH (relative to the ground)
because of the wheelspinning.
and then all of a sudden when you let your clutch out and pour 200+hp at the car in 2nd, almost any clutch will have trouble because its like trying to launch in 3rd gear.
this is a driver adjustment that will definately help solve this issue.
I honestly think about half of the people with clutch issues are experiencing this in full or partial effects.
the adjustment you make is a simple one.
Listen to your launches. get a bit of a chirp going....but make DAMN sure when you reach your redline in first gear your fully engaged with full traction.
you will find the shift to second feels a whole lot different.
um even when i dont drive it like i stole it, pretty much just cruising around i get the slippage, feels like the clutch engages and then bounces off a couple times and finally engages fully, and i get it in almost all gears but 5th, i can drive a stick perfect, my eclipse had 75000 miles and it was the original clutch, and they were all mine but 15000
Old Sep 29, 2006 | 09:36 PM
  #164
sethallen's Avatar
isn't this thread a little old by now...seems like it needs to be
Old Sep 30, 2006 | 08:55 AM
  #165
Badmunky's Avatar
Why?^^^^^^^^^^^^^^^^^^
Its still relivent. People still have clutch problems and probably always will.
There will be clutch threads on this site for years. Get used to it.
Later
Old Oct 6, 2006 | 10:01 AM
  #166
cds00bsmg's Avatar
can anyone verify that a different unit from the Vette or G6 or whatever can be swapped into the car without a ****-load of modification?
06MetallicBalt
Jul 20, 2025 08:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Trav3480
Sep 28, 2015 02:46 PM
