Finally going to intercool..
I got the parts to get my cav intercooled.
This is how I plan on running it. I have been to that it might be more beneficial to switch the pump and heat exchanger so that the pump doesnt heat up the coolant before going to the endplate.
Is this correct how I have it routed? Keep in mind I have a cavalier so I was never intercooled and dont have the stock heat exchanger.
Unfortunately yes..I bought the car supercharged from a local guy October of last year. It wasnt as bad in the winter but now it has to be done!
I dont know how he drove it like this to be honest.
Oh btw, do u have ur iat sensor in the manifold, using a tmap or do u have the iat sensor in the intake still, I really hope u have it in the manifold or using a tmap, otherwise ur car wont take advantage of the iat timing safety tables
LSJ Charged Air Cooling System Supercharger - YouTube
This vid seems to say its correct, although every dual pass setup diagram ive seen they have the hot coolant going through the pump instead.
On a stock cobalt ss/sc the pump pushes hot coolant into the heat exchanger, then out from the heatexchanger to the manifold, so its opposite to what you have however, I personally don't see switching it will cause any problems, as the pump will not heat the fluid up as stated earlier
I am reading IAT2 through my interceptor via the tmap.
