Finally going to intercool..
Old May 17, 2012 | 08:32 AM
cavfiredesire's Avatar
I got the parts to get my cav intercooled.
This is how I plan on running it. I have been to that it might be more beneficial to switch the pump and heat exchanger so that the pump doesnt heat up the coolant before going to the endplate.
Is this correct how I have it routed? Keep in mind I have a cavalier so I was never intercooled and dont have the stock heat exchanger.
Old May 17, 2012 | 07:01 PM
nhanson's Avatar
This whole time no intercooler?
that looks right
Old May 17, 2012 | 07:07 PM
Unfortunately yes..I bought the car supercharged from a local guy October of last year. It wasnt as bad in the winter but now it has to be done!
I dont know how he drove it like this to be honest.
Old May 17, 2012 | 09:56 PM
Sharkey's Avatar
the gm supercharger kit for the ecotec cavy/sunfire is non intercooled. the manifold is identical, however the endplate just has the hose barbs capped.
Old May 18, 2012 | 12:42 PM
mrbelvedere's Avatar
the pump isent going to heat the coolant up
Old May 18, 2012 | 01:27 PM
Blowncavy's Avatar
Keep this updated
You'll love it
Old May 18, 2012 | 10:26 PM
Glad....makes for a much much easier install with the factory hoses. Well a couple of them anyways.
Thats the correct routing though?
Old May 19, 2012 | 12:41 AM
SunburstSS's Avatar
On a stock cobalt ss/sc the pump pushes hot coolant into the heat exchanger, then out from the heatexchanger to the manifold, so its opposite to what you have however, I personally don't see switching it will cause any problems, as the pump will not heat the fluid up as stated earlier
Oh btw, do u have ur iat sensor in the manifold, using a tmap or do u have the iat sensor in the intake still, I really hope u have it in the manifold or using a tmap, otherwise ur car wont take advantage of the iat timing safety tables
Old May 19, 2012 | 12:49 AM
SunburstSS's Avatar
Oh Btw heat rises up, so u might wanna switch the cold outlet to the bottom, might not make a huge difference, but its better that way
Old May 19, 2012 | 12:50 AM
Blowncavy's Avatar
Why don't you post in the jbody.org?
Makes me sense to me
Old May 19, 2012 | 08:50 AM
If your refering to me I have.....the sites pretty dead.
Old May 19, 2012 | 09:46 AM
LSJ Charged Air Cooling System Supercharger - YouTube
This vid seems to say its correct, although every dual pass setup diagram ive seen they have the hot coolant going through the pump instead.
Old May 19, 2012 | 11:51 AM
nhanson's Avatar
Looks fine to me
Old May 19, 2012 | 09:40 PM
Im gonna go with it..its the easiest way.
Soon enough ill be going single pass or dual pass so itll all be changed soon anyways.
Old May 19, 2012 | 09:42 PM
I have a cav.....I dont know if they have safety tables lol.
I am reading IAT2 through my interceptor via the tmap.
06MetallicBalt
Jul 20, 2025 08:47 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
