Fix For Hesitation (2.0)
Okay, if you are one of the many who had problems with their car hesitating when you would go WOT after a couple of runs. Or If your have a gm stg 2 with a 2.85 pulley and you car started acting funny and hesitating after a 7k redline shift. The I HAVE THE FIX FOR YOU!
After changing a couple of things My car finally stopped doing it. I changed the VE tables a bit, Nothing happened, I changed my cylinder protention higher, nothing happened and then BAM I Upped my MAF Fail signal (Code 0103)to 12500 up from 10000 and THATS IT>
now my car revs real happy to 7k and doesnt freak out. By the way you can only do this with HP tuners.
Hopes this helps many of you.
Later
Laz.......
Later
Laz.......
noice, that fixes 2 probs for me, the first one is a get a cel at about 6700 rpm, p0103, mass air volume, keep on deleteing it when it happens, only does it on cooler nights, and i do have a bog/hesitaion, sometimes too, so thats great, thanks man, so 12500 is the best number to jump to?
Later
Laz.......
Later
Laz.......
eh... I thought this was somewhat common knowledge.
Almost everyone I know has set thier MAF Fail to 12000hz since day one
noremorse you should have told me!!!!!!!!!!
Sep 28, 2015 12:51 PM
