Flow through tank instead of option b
Old Jul 16, 2014 | 01:49 PM
hoytshootr's Avatar
I have been thinking and doing some research and I don't see why this wouldn't work the same if not better than option b. If the coolant flows into the top of the flow through tank and out the bottom, it should bleed the air efficiently right? This also adds more fluid to the system than the option b because it is in the mainstream of the system.
If I'm completely wrong I would like to hear your opinion as of why... But in my mind this sounds right.
Thanks!
Old Jul 16, 2014 | 01:58 PM
Staged07SS's Avatar
Administrator
Administrator
It will not provide a continuous bleed like opt. b w/o a 0.040" restrictor orifice placed in a bleed line connected inline with the intercooling system.
Flow throughs are great for the track, because u can use them as an ice box, and as you mentioned it adds coolant to the system which helps to slow the rising of iat2 temps.
but a continuous bled system with no trapped air will always be more efficient.
Search this, there has been multiple discussion pertaining to the topic in the past. You will learn all the pros and cons as well.
Old Jul 16, 2014 | 02:14 PM
hoytshootr's Avatar
so could you tap the stock intercooler and run the bleed line to the flow through and it serve as a dual purpose tank?
Old Jul 16, 2014 | 02:19 PM
Staged07SS's Avatar
Administrator
Administrator
I think someone has done that in the past. That's why I mention to give it a search.
It's been a while since I read about flow throughs. Check it out man.
Old Jul 16, 2014 | 02:28 PM
Hockeyman's Avatar
Option B is simply an air bleeder running from the stock h/e. A flow through tank will not bleed the stock h/e.
Old Jul 16, 2014 | 03:13 PM
hoytshootr's Avatar
so i could just run the bleeder line into the flow through tank?
Old Jul 16, 2014 | 03:23 PM
Hockeyman's Avatar
sure could
Old Jul 17, 2014 | 08:21 AM
blueLNFftw's Avatar
Restrictor?
Hmmmm. I dont recall a restrictor in my option B line.
Could that be why I get gurgling coolant in the tank?
Old Jul 17, 2014 | 08:47 AM
Staged07SS's Avatar
Administrator
Administrator
Restrictor?
w/o it, you do not have a properly functioning opt b setup.
pick one up from CED or any auto parts store.
Old Jul 17, 2014 | 08:50 AM
blueLNFftw's Avatar
Where does it go?
Could it be the reason my temps do not drop that fast?
Last edited by blueLNFftw; Jul 17, 2014 at 08:50 AM. Reason: Automerged Doublepost
Old Jul 17, 2014 | 09:08 AM
mrbelvedere's Avatar
the option b also functions as a flow through coolant is constantly flowing through the bleed line even with the restrictor
Old Jul 17, 2014 | 09:09 AM
Staged07SS's Avatar
Administrator
Administrator
Where does it go?
It goes in the 1/4" bleed line.
Yes, trapped air will raise iat2 temps.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
riceburner
Sep 26, 2015 12:57 AM
