Fluttering from Bypass or Diverter valve on Charger?
Old Sep 21, 2006 | 10:40 AM
spoolin's Avatar
Has anybody experienced this?
I doubt its belt slip, Boost does not fluctuate, and there is no Belt dust present anywhere.
Sounds like the valve is opening and closing, I know the boost is handed out by the GM boost solenoid, but I assume there is a spring in that valve?
Old Sep 21, 2006 | 11:05 AM
06blackg85ss's Avatar
blown diapragm in the boost bypass valve two cars around me already had that happen
Old Sep 21, 2006 | 11:13 AM
Cobalt_Supercharged's Avatar
When does it happen? If it's the top of the RPM band, it seems to be something the computer does. I noticed it in the last 500 or so RPM when I put on a Mechanical boost gauge. I have never heard it, I just watched the gauge flutter between 8-12 psi for the last little bit.
Old Sep 21, 2006 | 11:19 AM
patathSS's Avatar
Yeah mine was fluttering and I bet that diaphram is shot. I but a MBC inline and it took away the flutter. It happens to me at about 9.5psi around 4000rpm. Then the boost will jump to 15and slowly build to redline. With the MBC the car just instantly hits 17.5psi and keeps building to 20.
Old Sep 21, 2006 | 11:22 AM
Damn I gotta try that...
Old Sep 21, 2006 | 11:30 AM
patathSS's Avatar
The car was fine for quite a while but within the last month it started doing it.
Old Sep 21, 2006 | 11:36 AM
Mine so far was ok (minus tranny) but with the 2.6 for 2 months and 2.55 never had a problem
Old Sep 21, 2006 | 01:06 PM
BallsoutBalt's Avatar
Question
What is a "MBC"?
Old Sep 21, 2006 | 01:17 PM
Manual boost controller
DWK5150's Avatar
Originally Posted by BallsoutBalt
What is a "MBC"?
Old Sep 21, 2006 | 01:21 PM
NoRemorse's Avatar
I doubt the diaphram is shot. Mine was doing this, but I found it was an 'issue' with 'Tourque Managment'. Remove all TQ mangmnt and the flutter will most likly go away, allowing A LOT more boost.
Old Sep 21, 2006 | 02:08 PM
Are there any "Hot to's" on removing it?
Old Sep 21, 2006 | 02:09 PM
NoRemorse's Avatar
regarding my post?
Old Sep 21, 2006 | 02:24 PM
leviticus88's Avatar
My car makes a sound at quarter throttle or under 3500 rpm. Its best discribed as a flutter. When i go wot it goes away. Is this what your talking about? I don't fully understand what your all talking about. If someone could explain to me better. thanx
Old Sep 21, 2006 | 02:25 PM
NicD's Avatar
It's been removed already, that's not the problem.
Old Sep 21, 2006 | 02:34 PM
Kinda wierd cuz I got on it on the way to work today and the Flutter was no there. WTF?!
Old Sep 21, 2006 | 02:35 PM
Question
Where can I get on and how much is it. How hard to put on?
Old Sep 21, 2006 | 02:36 PM
NoRemorse's Avatar
Assuming that it IS TQ managment, the TQ is calculated and limited by the ECM. Differnt conditions can make the ECM calculate the TQ to be different, and maybe your not hitting the limit
Old Sep 21, 2006 | 03:32 PM
Old Sep 21, 2006 | 03:43 PM
I haven't tried the manual boost control route... my car was still fine til the tranny blew up
Old Sep 21, 2006 | 11:05 PM
patathSS's Avatar
I have my boost control with HPT turned off. Full boost is allowed at all RPMs. I didn't have a problem for a logn time and I have just noticed it in the last few weeks. Put the MBC in and no more problems.
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
yellow dragon
Sep 28, 2015 09:49 PM
Trav3480
Sep 28, 2015 02:46 PM
dennis69
Sep 28, 2015 02:16 PM
