Fuel filter change problem
So im under the car right now im trying to get the 2 connectors off the one side of the filter iv hit them with pb blaster and when i press in both side they wont come off any advice? Lol everything ido i end up with problems
Not being a smartass but here. Do you have the tool?
http://www.google.com/url?sa=t&sourc...CEvet3MTfA-x7g
Ok i got the two lines off now im trying to get the line off that requires the tool and its not coming off lol ******* **** sucks, im stuck with a plastic tool im assuming its deep enough in the thing to release the line
I don't get the Plastic tool, I got Aluminum tool. I got them same place at AutoZone, IMO Aluminum tool is better than Plastic cause Plastic dig in short and Aluminum dig in deep. They are very easy to take off but of course Gas! It pour out a whole buncha Fuel, Yeah it's Sucks but it works.
lmao. the metal ones i bought worked fine, all they do is just compress the little lock ring in the fitting so you can slide it over the nipple on the fuel filter. so i mean plastic ones work too, just a pain in the ass. try taking off the valve cover oil feed line............that thing is a pain in the dick because you CANT use this tool on it, no room to. so u gotta improvise with other tools lol.
is this the right one ?
OEM/Fuel line disconnect tool set (25043) | Line Disconnect Tool | AutoZone.com
i dug at it with a tiny screwdriver until i messed up the filter enough to rip it off with my awsome muscles! I tore the metal piece that holds the fuel filter on off the fuel filter, sooooo yeah, have fun with that!
I did thought about using screwdriver at 1st but I didn't. So, I bought that Metal Tool and I was surprised how much Fuel came out. Screwdriver gets Me feeling uneasy on the spot cause what if You are fighting it then FINALLY Popped Out. Whole Fuel will be Spraying all over Your Face! LMAO! That will be ******* HILARIOUS of the Day! LOLOLOL!
