Fuel filter change problem
Old Apr 5, 2013 | 10:10 AM
Vander Nars's Avatar
So im under the car right now im trying to get the 2 connectors off the one side of the filter iv hit them with pb blaster and when i press in both side they wont come off any advice? Lol everything ido i end up with problems
Old Apr 5, 2013 | 10:14 AM
574's Avatar
574
Not being a smartass but here. Do you have the tool?
http://www.google.com/url?sa=t&sourc...CEvet3MTfA-x7g
Old Apr 5, 2013 | 10:30 AM
Ok i got the two lines off now im trying to get the line off that requires the tool and its not coming off lol ******* **** sucks, im stuck with a plastic tool im assuming its deep enough in the thing to release the line
Old Apr 5, 2013 | 10:41 AM
YelCal7's Avatar
I don't get the Plastic tool, I got Aluminum tool. I got them same place at AutoZone, IMO Aluminum tool is better than Plastic cause Plastic dig in short and Aluminum dig in deep. They are very easy to take off but of course Gas! It pour out a whole buncha Fuel, Yeah it's Sucks but it works.
Old Apr 5, 2013 | 10:46 AM
bluebalt69's Avatar
I have the 3/8 plastic tool. Works fine. Just gotta finaggle it. If I wasn't so cheap, I woulda bought a whole filter remover kit. Do you have the right size tool?
Old Apr 5, 2013 | 10:52 AM
umrdyldo's Avatar
Honestly I worked on that damn thing to the point I almost gave up and then it slipped out.
Unreal how frustrated I was.
Old Apr 5, 2013 | 10:54 AM
Staged07SS's Avatar
Administrator
Administrator
I have the metal tool, and it makes the job super easy.
Never had any luck with the plastic ones.
Old Apr 5, 2013 | 10:56 AM
and you can get the metal tool at autozone? i'm at 66k, bout time to change it i think
Old Apr 5, 2013 | 10:59 AM
Tcobalt421's Avatar
good to know im changing mine this sunday
Old Apr 5, 2013 | 11:00 AM
2009CobaltLT's Avatar
Hmm... I bought a filter a while ago and forgot, maybe I should do this while I'm under there this weekend
Old Apr 5, 2013 | 11:01 AM
Im gonna have to buy a metal one only reason i didnt was because it said for standard ford fittings so i got plastic instead since it didnt list any make.
Old Apr 5, 2013 | 11:03 AM
yellowsupercharged06's Avatar
im doing mine tomorrow lol... i better not have any issues .... link to the correct metal tool ?
Old Apr 5, 2013 | 11:04 AM
Staged07SS's Avatar
Administrator
Administrator
I bought mine at Advance Auto, so I'm sure Auto Zone has them to.
Old Apr 5, 2013 | 11:07 AM
dcrep06's Avatar
yes they have them. i had to buy a set for the Valve cover quick release lines. def do the metal ones though.
Old Apr 5, 2013 | 11:13 AM
******* plastic trash why do they even make the **** if it dont work lol
Old Apr 5, 2013 | 11:28 AM
dcrep06's Avatar
lmao. the metal ones i bought worked fine, all they do is just compress the little lock ring in the fitting so you can slide it over the nipple on the fuel filter. so i mean plastic ones work too, just a pain in the ass. try taking off the valve cover oil feed line............that thing is a pain in the dick because you CANT use this tool on it, no room to. so u gotta improvise with other tools lol.
Old Apr 5, 2013 | 02:57 PM
Ok i got it off after i spent 15 bucks on a 3/8 metal disconnect, we will see if this help my issue with the car.
Old Apr 5, 2013 | 03:00 PM
is this the right one ?
OEM/Fuel line disconnect tool set (25043) | Line Disconnect Tool | AutoZone.com
Old Apr 5, 2013 | 03:03 PM
I bought a single with the rubber band
Old Apr 5, 2013 | 03:15 PM
thats the one
Old Apr 5, 2013 | 03:17 PM
sweet thanks guys. ill let ya know how it goes
Old Apr 5, 2013 | 03:25 PM
jp1600's Avatar
i dug at it with a tiny screwdriver until i messed up the filter enough to rip it off with my awsome muscles! I tore the metal piece that holds the fuel filter on off the fuel filter, sooooo yeah, have fun with that!
Old Apr 5, 2013 | 05:45 PM
rectorc08's Avatar
I also used a tiny screw driver, screw the tool. Prop them open with 2 tiny screw drivers.
Old Apr 5, 2013 | 07:03 PM
YelCal7's Avatar
I did thought about using screwdriver at 1st but I didn't. So, I bought that Metal Tool and I was surprised how much Fuel came out. Screwdriver gets Me feeling uneasy on the spot cause what if You are fighting it then FINALLY Popped Out. Whole Fuel will be Spraying all over Your Face! LMAO! That will be ******* HILARIOUS of the Day! LOLOLOL!
Old Apr 7, 2013 | 12:15 AM
If u pulled the fuel pump fuse, and let the car runs till it dies it wont be alot of fuel coming out, i had maybe a cup worth of fuel come out on me.
