fuel pressure?
Old Sep 21, 2010 | 08:37 PM
StevesBlack06's Avatar
fuel pressure?
just finished hooking up my OTTP return style fuel system. just outta curiosity what should my fuel pressure be? thanks in advance CSS
Old Sep 23, 2010 | 09:16 PM
no one?
Old Sep 23, 2010 | 09:32 PM
ziggity's Avatar
58 psi i believe
Old Sep 23, 2010 | 09:34 PM
elite_Cyborg's Avatar
You can make it whatever you want it to be, but stock is 58psi Im running a 42 base now with 1000s though.. Oh yea, check this with no vac line hooked up to the regulator
Old Sep 23, 2010 | 09:55 PM
Area47's Avatar
Rent me! per hour
this
Old Sep 28, 2010 | 10:37 PM
thanks guys. i really appreciate it.
Old Sep 29, 2010 | 09:28 AM
csementuh's Avatar
Like they said 42 is good. I would think however that 43.5psi is perfect...
80's flow 80lb/hr at 43.5psi. So if your base is 43.5psi, you can use 2 as the voltage multiplier and 40 as the injector flow in HPT...
That gives you a nice 37ish psi idle, and shoots your pressure more than high enough for top end fueling for a moderate pulley E85 TVS.
Anyone want to explain why 42 is the sweet spot instead?
Old Oct 1, 2010 | 03:30 AM
slvr 04 rl's Avatar
subscribed for near future
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
