fuel pump!???!?!?!
Old Jul 16, 2007 | 04:48 PM
Omega_5's Avatar
Originally Posted by Cobalt_Supercharged
9.5:1 is stock compression. I haven't heard of anyone using the 50# injectors. I heard there is a vendor selling them, but I have yet to see someone using them so I don't know if they would result in a problem like the 60's do.
What's the problem with 60's?
I assume you mean idle problems, right?
Old Jul 16, 2007 | 08:56 PM
Cobalt_Supercharged's Avatar
No proper tuning fixes the idle issue. Blown 4-banger got his idle tuned in not too long before he blew his motor. The issue is the injectors being double the size of stock and the fuel rail unable to accomodate that much flow. Atleast that is my speculation of cylinder 4 blowing on the cars running 60's.
Old Jul 16, 2007 | 11:24 PM
burntorange's Avatar
so 50's will be fine? or my stage 2 42.5's?
Old Jul 17, 2007 | 09:27 PM
A 2.8 is pushing the limits of the 42.5's with the stock fuel system. I would look into boosting the fuel rail pressure first, but I have yet to see anyone do that.
Old Jul 17, 2007 | 09:40 PM
with a fuel pressure regulator?
Old Jul 17, 2007 | 09:46 PM
I think a larger pump, return line, and boost referenced regulator would be the best option. Some people have mentioned the Kenne Bell Boost-A-Pump, but I'm familiar eoungh with it to know how well it works.
Old Jul 17, 2007 | 10:07 PM
88cobaltSS's Avatar
Originally Posted by freakta
but dont diesels run there cams into the injectors for extra pressure
No the injectors are only actuated by the camshaft to initiate the plunger on the injector to start the spray process. Newer diesels do run really high fuel pressures though. For example the cummins common rail runs around 5000 psi in the rail and once sprayed into the cylinder through the tiny nozzle holes the injection pressure increases to around 28,000 psi.
Old Jul 17, 2007 | 10:58 PM
Jmc007's Avatar
I was wondering why the GM Stage 3 still include the 42's (those from Stage 2) for a 3" pulley (which is 15 PSI) PLUS a 50 shot of dry nitrous ...
So ... does the Stage 3 PCM send a higher voltage to the pump when nitrous is on ???
Old Jul 18, 2007 | 12:24 AM
That is a really good question. I would think the regulator would negate the extra pressure in the line, but may be not. I wonder if the GMS3 PCM alters the regulator's pressure level.
Old Jul 18, 2007 | 12:26 PM
Area47's Avatar
Rent me! per hour
kind of why i put my 2.8 back on.
then again, water injection helps create a saftey blanket.
take out fuel, spray additional sourced fuel, run same a/f ratio. everyones happy
Old Jul 18, 2007 | 04:04 PM
  #36
that is exactly what I am going to do then. I will hold off on my GIANT hp build. I will just go over the 300whp mark then. you guys are really really helpful. thanks
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
