FYI- Info for Trunk Mount Methanol Install
Old Feb 18, 2008 | 10:37 AM
QuikSilverSS's Avatar
I have the Devils Own progressivly controlled methanol injection kit. I ended up going for the trunk mount set up where I mounted the tank and pump to a cut piece of plexi-glass, which i then mounted to the trunk on the passenger side opposite the subwoofer. YOU WILL NEED MORE THAN THE SUPPLIED AMOUNT OF HOSE FOR THIS INSTALL" the kit comes with 15ft of nylon 1/8" hose and would recommend approx 25ft for a safety. I could not connect my hose lines becuase not enough was supplied.
However the kit is great, vendor was excellent to deal with, and the install was easy, I can't wait to get it all hooked up.
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
dieGone
Oct 1, 2015 06:27 PM
grampss
Sep 27, 2015 08:51 PM
