View Poll Results: What kind of gas do you put in your Cobalt SS s/c
Regular
8.91%
Premium 93 Octane
81
80.20%
Higher than 93 Octane
10.89%
Voters: 101. You may not vote on this poll
Gas Octane
Originally Posted by 2K5SS/SC?
93 is definately enough. Don't go lower though, as the car requires Premium fuel only! That is all I run, because that's the highest I can get where I'm at.
87 - Regular
89 - Mid-grade
93 - Premium
I go with 89, as I read on my old 2.2 somewhere that it is the recommended fuel, as is 5W-30 for oil if I am not mistaken.
Your car might be different, and I might be wrong! But if you have Stage 2 then I would go with 93 just to reduce, I believe its called "combustion"
Originally Posted by kadumel
Where I am from, there is
87 - Regular
89 - Mid-grade
93 - Premium
87 - Regular
89 - Mid-grade
93 - Premium
Originally Posted by srt-killer
Damm...i wish i could run 93. the only thing they have in az is 91 unless u go to the track or something, but than its like $5 a gallon.
BTW will 91 octane be enough for a Stage 2 Cobalt s/c?
I run 91 (highest I can go) out here, but next time I go to the track, before I leave the track I'm fillin it up with 105 unleaded racing gas!!!! HELL YEAH!!!!!!!!!! Then with that gas in it I'm gettin it chassis dynoed! Can anyone say 260+ whp?!?!?
*EDIT if anyone knows will our cars run on LEADED gas? If they do I'm goin with 118 leaded instead, then 280 whp!!!
Originally Posted by PauL500x
Yea I think I can only get 91 too at Costco and I forgot to add that to the poll. If there was any way to change that...
I wouldnt run leaded fuel it clogs the Cat Converter and O2 sensor
lead deposits
you might be able to get away with a 50:50 dutch load 91/race gas but i would ony do a couple of gallons each not a whole fill up.
lead deposits
run 93 regaurdless of what anyone says......you can be cheap and save the 5cents a gallon or spend the 93 to better protect your 23k investment....detonation is not cool and 93 will def be safe from it....just liek witht he intense stage 3 i heard some kids sayin the car knocks but its ok, NO its not ok.....93 octane stage 0 or stage 2, intake or exhaust use it....
lead deposits
lead deposits
detonation is when the fuel/air mixture explodes before the spark plug fires. basically its like hitting the piston with a sledge hammer, because the is two different combustions on two different areas of the pistons, so yes there is definatly damage when detonation happens, now your motors not gonna blow up as soon as it starts, but if it does happen get higher octane gas ASAP!
