View Poll Results: What kind of gas do you put in your Cobalt SS s/c
Regular
8.91%
Premium 93 Octane
81
80.20%
Higher than 93 Octane
10.89%
Voters: 101. You may not vote on this poll
Gas Octane
Old May 2, 2006 | 09:16 PM
PauL500x's Avatar
Gas Octane
What octane would you reccommend for a s/c Cobalt with stage 2? Is 93 enough?
Old May 2, 2006 | 09:18 PM
gforce477's Avatar
Yes !
Old May 2, 2006 | 09:19 PM
2K5SS/SC?'s Avatar
93 is definately enough. Don't go lower though, as the car requires Premium fuel only! That is all I run, because that's the highest I can get where I'm at.
Old May 2, 2006 | 10:13 PM
l Sh1ft l's Avatar
Ah. I made the first vote lol. It said what do you put in yours. Didn't ask about stg 2. I put regular in my ss/sc.
Old May 2, 2006 | 10:36 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
my main choices are 91 or 94 and I always go 94.
Old May 2, 2006 | 10:40 PM
Tomtwtwtw's Avatar
91's the highest we have out here, but it will do just fine. Anything over 90 is considered premium as far as GM says, and they say you must use premium on Stage II.
Old May 2, 2006 | 10:43 PM
kadumel's Avatar
Where I am from, there is
87 - Regular
89 - Mid-grade
93 - Premium
I go with 89, as I read on my old 2.2 somewhere that it is the recommended fuel, as is 5W-30 for oil if I am not mistaken.
Your car might be different, and I might be wrong! But if you have Stage 2 then I would go with 93 just to reduce, I believe its called "combustion"
Old May 2, 2006 | 10:47 PM
Tomtwtwtw's Avatar
87 - Regular
89 - Mid-grade
93 - Premium
Detonation I think you mean...combustion is good. It's how our engines make power.
Old May 2, 2006 | 10:49 PM
kadumel's Avatar
Yeah those damn loratabs are fading me right now...
Old May 2, 2006 | 11:03 PM
alleycat58's Avatar
I run nothing but 93 in mine. Tried 89 and thought the car was going to die on me. It just wouldn't hardly run at all. Tried 94 and saw no improvement over 93, so I stick with 93.
Old May 2, 2006 | 11:05 PM
WSFrazier's Avatar
I've been doing 93, there are a few places around that got 94 but not worth the drive for each fillup. I am thinking about using 87 though since I will be trading her in anyhow.
Old May 2, 2006 | 11:08 PM
srt-killer's Avatar
Damm...i wish i could run 93. the only thing they have in az is 91 unless u go to the track or something, but than its like $5 a gallon.
Old May 2, 2006 | 11:49 PM
PauL500x's Avatar
Yea I think I can only get 91 too at Costco and I forgot to add that to the poll. If there was any way to change that...
BTW will 91 octane be enough for a Stage 2 Cobalt s/c?
Old May 2, 2006 | 11:56 PM
Blown 4-banger's Avatar
I run 91 (highest I can go) out here, but next time I go to the track, before I leave the track I'm fillin it up with 105 unleaded racing gas!!!! HELL YEAH!!!!!!!!!! Then with that gas in it I'm gettin it chassis dynoed! Can anyone say 260+ whp?!?!?
*EDIT if anyone knows will our cars run on LEADED gas? If they do I'm goin with 118 leaded instead, then 280 whp!!!
Old May 2, 2006 | 11:58 PM
hondaeater's Avatar
According to the manual, it says to run premium. I've been running 93 or 94 since I got the beast.
Old May 3, 2006 | 12:47 AM
Tomtwtwtw's Avatar
91 is fine for stage 2.
Old May 3, 2006 | 03:55 AM
Gory's Avatar
I wouldnt run leaded fuel it clogs the Cat Converter and O2 sensor
lead deposits you might be able to get away with a 50:50 dutch load 91/race gas but i would ony do a couple of gallons each not a whole fill up.
Old May 3, 2006 | 05:56 AM
cavy9psi's Avatar
run 93 regaurdless of what anyone says......you can be cheap and save the 5cents a gallon or spend the 93 to better protect your 23k investment....detonation is not cool and 93 will def be safe from it....just liek witht he intense stage 3 i heard some kids sayin the car knocks but its ok, NO its not ok.....93 octane stage 0 or stage 2, intake or exhaust use it....
Old May 3, 2006 | 11:16 AM
p7x's Avatar
p7x
91 b/c this **** hole doesnt have anything higher. When I get back to Ontario 93+.
Old May 3, 2006 | 04:44 PM
RickZ28's Avatar
In Quebec, Canada the
Regular is 87
Mid-Grade is 89
Premium is only 91 max
Old May 3, 2006 | 05:31 PM
If you read I said it was either 118 leaded OR 105 UNLEADED, which obiously I'm going with the unleaded 105.
Old May 3, 2006 | 08:58 PM
tio's Avatar
tio
Putting regular octane into a CobaltSS is like banging a supermodel in the dark.
You still get laid but miss out on the best part of the ride
Steve.
Old May 3, 2006 | 10:15 PM
PauL500x's Avatar
I wish I could get 93 octane. BTW what exactly is detonation and does it cause any long term damage? What exactly does the car knocking me too? Thanks...
Old May 4, 2006 | 01:24 AM
detonation is when the fuel/air mixture explodes before the spark plug fires. basically its like hitting the piston with a sledge hammer, because the is two different combustions on two different areas of the pistons, so yes there is definatly damage when detonation happens, now your motors not gonna blow up as soon as it starts, but if it does happen get higher octane gas ASAP!
Old May 4, 2006 | 04:12 AM
snowyak's Avatar
im gonna say all u guys are lucky. cause up here in alaska our ratings are 87, 88.5?!?!?! and 90. i have YET to find a place anywhere up here with more then 90
