Gaskets for Down Pipe
Old May 30, 2012 | 10:30 PM
Gelladuga69's Avatar
I'm replacing the down pipe on my car and was wondering if I need to get new gaskets?
Just to prepare, I've looked at my local NAPA and they only list gaskets for Auto's, but that shouldn't matter right?
Manifold to Flange is 3 bolt, and Flange to cat back is two bolt, right?
I guess I would need some new hardware (bolts) too since I would suppose they're pretty rusted on atm?
Thanks in advanced.
Old May 30, 2012 | 10:33 PM
CobaltItaliano's Avatar
Yes and Yes. Need a new gasket. header to DP is a 3 bolt gasket, and the dp to catback is 2 bolt flange.
I would also get new hardware
Old May 31, 2012 | 08:13 AM
Any place you would recommend to get this stuff at?
I have the normal auto places in my area. Oriellys, advanced, autozone, etc. and looking online they say they don't have them, lol.
Maybe its cause I'm specifying the vehicle.. are gaskets universal?
Old May 31, 2012 | 08:16 AM
Maccoy316's Avatar
wouldn't hurt to replace the parts, especially your gaskets.
Old May 31, 2012 | 08:36 AM
My dealership parts dept. is open late today.. I'll see if I can get everything there first.
Old May 31, 2012 | 08:50 AM
Staged07SS's Avatar
Administrator
Administrator
Check out Crate Engine Depot.
I recommend using genuine gm gaskets.
I've used aftermarket gaskets in the past, and they did not seal well.
Cobalt Lower Exhaust Manifold Gasket 15235773
Converter to Exhaust Pipe Gasket 15231157
Old May 31, 2012 | 08:51 AM
Thanks for the part numbers. You think they would get here by Saturday if I ordered them today? I need them this weekend.
Also, what hardware is needed. 2 14mm nuts and bolts and 3 15mm nuts and bolts? Or are there specific part numbers for those?
Old May 31, 2012 | 08:54 AM
Staged07SS's Avatar
Administrator
Administrator
You can ask Tom (Crate Engine Depot) about shipping.
They ship fast.
U can reuse your existing hardware if you have it.
If not, the nuts and bolts can be found at Crate Engine Depot as well.
Old May 31, 2012 | 09:05 AM
They ship fast.
I do have it, but I'm betting that its all rusted out and I'll probably have to drill or something, lol.
But thanks a lot for your help.
Old May 31, 2012 | 09:15 AM
Staged07SS's Avatar
Administrator
Administrator
You're welcome.
Old May 31, 2012 | 09:32 AM
Has anyone used ZZP's gaskets? Specifically, downpipe and collector.
Old May 31, 2012 | 10:29 AM
Staged07SS's Avatar
Administrator
Administrator
I have, and they are the ones I was taking about.
I ran them with one of their downpipes back in the day, and I had an exhaust leak.
When I installed the GM gaskets the leak went away.
What I always recommend to people running the stock manifold, gmpp manifold, or shorty header to a stock downpipe or zzp downpipe is the following:
- Genuine GM manifold to head gasket
- Genuine GM manifold to downpipe gasket
- Remflex 2-bolt flange gasket for the downpipe to catback connection
This has been my gasket setup for years, and I have always been leak free.
Old May 31, 2012 | 10:39 AM
574's Avatar
574
Staged is right they do **** fast, and those are good gaskets. As to drilling the bolts off.... Good luck, I would try to unbolt them very hard before resorting to drill. Mine very very rusted, you just gotta try real hard
Old May 31, 2012 | 10:40 AM
YelCal7's Avatar
I use Remflex Header to Downpipe Gasket. It's worth it and it stop/seal up the leak. That way you won't have to worry about them later on.
Old May 31, 2012 | 11:12 AM
SaberD's Avatar
the zzp gasket is crushable and is for one time use. haven't had any issues with mine knock on wood. only used it because it came with the dp and my oem one had 50k on it.
Old May 31, 2012 | 11:20 AM
Staged07SS's Avatar
Administrator
Administrator
So are the GM gaskets....
The ZZP gaskets are just not made of the same material, and did not seal well on my car.
Old May 31, 2012 | 02:02 PM
Again, thanks for the feedback guys. Just seeing what my options are.
Trying to get this done this weekend, since I have a pair of extra hands available, so I'm not trying to order anything that wouldn't get shipped to me this weekend, and ZZP is in the state.
Gonna hope my dealership just has the gaskets.
Old May 31, 2012 | 02:04 PM
Staged07SS's Avatar
Administrator
Administrator
The dealership should have them....
Old May 31, 2012 | 02:18 PM
Yes, they should. Question is if they have them in stock right now. Everything I've had to get for this car from the dealership had to be ordered. Except for my stupid sunroof button bezel.
Old May 31, 2012 | 05:45 PM
Dealership had both. Ended up paying $26..
Old May 31, 2012 | 09:50 PM
Blinker fluid's Avatar
finishing it off with some High temp liquid gasket for an extra seal isnt bad either.
Old Jun 1, 2012 | 08:28 AM
I thought I read in a How-To somewhere to not use that stuff.
Old Jun 1, 2012 | 09:07 AM
Permatex High temp RTV silicone liquid gasket? Shops use it, I use it all the time. No problems. Haven't heard bad things. Link me the how to
Old Jun 1, 2012 | 09:22 AM
Eh, I don't wanna get caught looking for it at work.
There's a couple how-to's on down pipes and one of them said not to use a liquid gasket, iirc.
Old Jun 2, 2012 | 05:48 PM
I got the down pipe changed.
Took longer than expected, as usual.
I had to saw one bolt off the two bolt flange, because it was so rusty.
I'm really happy since my exhaust sounds 20 times better now and I can actually run my Megan without the silencer and it sounds pretty nice and not just loud anymore.
