gauge question...help please.
Old Mar 23, 2007 | 07:27 PM
co-yellow-balt's Avatar
Does anyone have a autometer Cobalt series Air/fuel gauge installed in there car?
I installed mines and apparently its suppose to light up blue like in this picture below but mine does not...anyone have this problem?
only helpful comments prefered!
Old Mar 23, 2007 | 07:28 PM
NJHK's Avatar
Honestly, you should have gotten a wideband if you're trying to get a acurate a/f ratio.
Old Mar 23, 2007 | 07:29 PM
RuSSo-29's Avatar
Y? Is the Auto meter that bad?
Old Mar 23, 2007 | 07:32 PM
no mine is just narrowband, meaning its like 1/4 as accurate as a wideband.
i must need blue backlighting!!!!!!!!!
Old Mar 23, 2007 | 07:40 PM
RuSSo-29's Avatar
lol, oh, I c I that 1 looks the best oput of all of em actually......
Old Mar 23, 2007 | 07:45 PM
Jimmys2007CobaltSS/C's Avatar
autometer air/fuel ratio is ac ting up wiot problems? im thinking bout getting one 2
damn
Last edited by Jimmys2007CobaltSS/C; Mar 23, 2007 at 07:45 PM. Reason: Automerged Doublepost
Old Mar 23, 2007 | 07:47 PM
damn
could be just one bad one in the bunch or something unless i hooked it up wrong...
red to ignition fuse
black to ground
last wire to purple/white stripe wire from ECU
Old Mar 23, 2007 | 07:48 PM
NJHK's Avatar
Has nothing to do with auto-meter.
Like said, a narrowband sensor is made to read to a limitation...it goes of a stoich of 14.7 a/f but it can't tell you how lean or how rich you are to a "T".
You'd need to add a aditional wideband sensor and a wideband gauge with it (digital gauge) to read what you are running.
Old Mar 23, 2007 | 08:52 PM
yellowcobaltss05's Avatar
i know you said helpful comments only but that gauge is not going to be anywhere near accurate as the AEM wideband
Old Mar 23, 2007 | 08:56 PM
all im asking is if anyone knows why its not lighting up...
Old Mar 23, 2007 | 08:57 PM
wait so it doesn't light up at all??
Old Mar 23, 2007 | 08:59 PM
one the digital air/fuel lights up...like the green/orange/red the part that bounces. but its suppose to have a blue backlight.
Old Mar 23, 2007 | 09:01 PM
maybe they advertised the picture of it wrong on the website. As long as everything works your good, but call them up from whoever you bought it from and ask why its like that and see if you can get the color you want.
Old Mar 24, 2007 | 05:23 PM
bump....anyone know the reason?
Old Mar 27, 2007 | 07:28 PM
stvn's Avatar
i dont want to get a wideband, because i dont want to void my warrenty. but what wire can i tap into on the pcm or whatever its called, to get some kind of reading. do you have any pictures or any instuctions?
Old Mar 27, 2007 | 10:43 PM
05redline's Avatar
Is the bulb in correclty?
Old Mar 28, 2007 | 04:24 PM
when i called apparently those were the old models. which is gay and it doesnt look good at all with no backlight. is there any possible way to modify to gauge and install a bulb yourself to make a backlight, anyone know?
Old Mar 29, 2007 | 06:52 PM
Boost Fr33k's Avatar
i actually had this gauge when i first bought my car. ok so it aint no tuning gauge but it was cool looking so w.e., anyways there are 2 models for this gauge one with and another without the backlight. you obviously got the one without the backlight. did u correctly install the wires?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
