Gen 4 Lifters: Closer Look
Old Jun 8, 2015 | 05:38 PM
20Tsaabsteve's Avatar
As the title implies, here is a guts view of the gen 4 lifters. They are definitely redesigned, the spring is definitely stiffer, it is a two piece design now internally with an internal snap ring to hold them together. This was brought up in the "why camshafts do not perform well" thread so I thought it would be better to start a new thread vs. post on that one. Also, the oil feed hole is just slightly larger on the new lifter, and the top rocker/follower feed hole is smaller. Seems like the lifters would be less likely to collapse, but hard to say how much better they are than previous generations.
And the internals:
Crap, will repost internal pics as for some reason they are not full size.
Old Jun 8, 2015 | 06:31 PM
Bass_Waves's Avatar
Interesting
Old Jun 8, 2015 | 06:48 PM
Someone with cams should throw these in and see if they pick up any power
Old Jun 9, 2015 | 12:26 AM
Sharkey's Avatar
id love to see results back to back on a car with cams or even just stiffer springs.
Old Jun 9, 2015 | 12:55 AM
07blackg5's Avatar
Slobodan Milošević
Are they the same external dimensions?
Old Jun 9, 2015 | 07:42 AM
Staged07SS's Avatar
Administrator
Administrator
I may test these out this upcoming winter when I work on the car again.
Old Jun 9, 2015 | 07:54 AM
Haven07's Avatar
This is very interesting indeed
Old Jun 9, 2015 | 08:20 AM
Bass_Waves's Avatar
I have 82# spring n stage 3 lsj t cams. Maybe I'll try
Old Jun 9, 2015 | 08:36 AM
07blackg5's Avatar
Slobodan Milošević
Did I miss a part number?
Old Jun 9, 2015 | 08:42 AM
the good thing is swapping these out doesn't require lifting the head lol. definately in for more info if these don't collapse as easy i'd love to buy a set. going solid sounds awesome but its alot of money and work. thanks for the info OP!
Old Jun 9, 2015 | 08:44 AM
Haven07's Avatar
I'm thinking of building a second motor for my car in the coming months, I may try these too
Old Jun 9, 2015 | 09:22 AM
Id test them myself but i dont have a setup that would benefit.
Old Jun 9, 2015 | 09:26 AM
Does anyone know if they use the same lifters on the intake and exhaust? I know the new motors have vvl on the intake cam which can be switched between 4mm lift and 10mm lift.
Old Jun 9, 2015 | 09:59 AM
07blackg5's Avatar
Slobodan Milošević
if they are different and the exhaust side fits, we should just be able to use all exhaust sides. I would assume they are all the same. The lash shouldnt change. That might actually be why they made them stronger (if in fact they are), because they were dealing with varying lift and were finding the old ones werent cutting it lol
Old Jun 9, 2015 | 11:10 AM
Haven07's Avatar
If I'm understanding what's happening correctly it seems that anyone building enough cylinder pressure would benefit from upgrading their lifters. So I'd think anyone running enough boost, even on stock cams, should see a gain. Someone please correct me if I'm wrong lol
Old Jun 9, 2015 | 11:18 AM
Hmm. That does make sense. Hell im down. How much is a set?
Old Jun 9, 2015 | 11:31 AM
YelCal7's Avatar
If I would had known about these when I did Equinox camshafts swap. I would had put those in!
Old Jun 9, 2015 | 11:33 AM
advise's Avatar
I have them
Work just the same as my old they just won't separate under high rpm
Old Jun 9, 2015 | 11:39 AM
Haven07's Avatar
Can you elaborate? They still collapse like the stock ones?
Old Jun 9, 2015 | 11:43 AM
advise's Avatar
Exactly they still collapse underload
They just won't bust open underload
Better design but still the same
Old Jun 9, 2015 | 11:50 AM
Haven07's Avatar
So running them is essentially burrowed time until they fail? So it's either solids or some how figure out how to run a physically bigger hydro lifter on the exhaust side that won't bleed as easily?
Old Jun 9, 2015 | 02:02 PM
07blackg5's Avatar
Slobodan Milošević
Can someone supply the part number? I might as well throw these in my build while it's torn down
Old Jun 9, 2015 | 05:07 PM
Part number is 12572638.
Old Jun 9, 2015 | 05:08 PM
07blackg5's Avatar
Slobodan Milošević
Thank you. I figure if they help or not, it's not going to hurt to have the revised part in my build.
Old Jun 9, 2015 | 05:10 PM
How do you know this? Just wondering for my own education. Sure the internal size isn't different concerning the diameter, but how have you tested to see they collapse?
