Ghost in my electrical
So my problem is intermittent no front right turn signal, ive changed the bulb and from what i can see all fuses are good, my rear right turn signal still works, just flashes fast. when the turn signal is not working both fillaments are lit up, even tho only one is supposed to. when its not working the drk blue wire at the bcm shows no voltage but when it is working it shows 2v - 11v like normal... when i pull the harness out of bcm and then plug it in again the signal works for a lil bit then after a few times being used goes back to not working...so my question... WTF?!?!
