View Poll Results: Those who have it. Which is better?
Stage 1 with smaller pulley
18
39.13%
stage 2
28
60.87%
Voters: 46. You may not vote on this poll
GM Stage 1/2 Thread: Merged
Old Apr 3, 2006 | 07:36 PM
  #451
retrop's Avatar
Bastard...
I hope to join the club in a few days. Def can't wait to hear your impressions!!!
  #452
Bad06SS's Avatar
Geez! How far are you driving? It should've only taken 10 min.!!! We're excited here!
Old Apr 3, 2006 | 07:39 PM
  #453
NJBLUESS's Avatar
OMG!!! What a difference!!! I could not stop spinning the tires, It's wet out. This engine woke up, especially in the upper RPM. Cruising in second and punched it, through my and my passangers' heads back.
Took about 2 hrs to install, the hub was a very tight fit.
YES, the redline is right around 7k, more like 6800 on my tach.
Sorry, I didn't watch my boost gauge, will do on the way home.
  #454
memphisr24's Avatar
10 minutes ha! I'd be out all night
Old Apr 3, 2006 | 07:40 PM
  #455
gonzo's Avatar
I know what happened, he burned up his clutch and is stuck in first gear
  #456
BlackSS05's Avatar
OMFG i want it NOW.
Old Apr 3, 2006 | 07:41 PM
  #457
TheToolmaker's Avatar
AWESOME!! Thanks for the impressions!!
Old Apr 3, 2006 | 07:42 PM
  #458
JCswoosher2's Avatar
i want to see a dyno
  #459
Bad06SS's Avatar
NO kidding??!!! So, it's true, 7K redline! I hope this is true, and not that it went to 7K only because you're spinning......
  #460
victory_red_SS's Avatar
LSX RWD S/C conversion
Yea with all that new power he should be on this side of the continent by now. I hope it is lots of fun. I can hardly wait for mine to come in. Of course in 3 weeks I hope to be finished the 300+hp build.
Old Apr 3, 2006 | 07:44 PM
  #461
Bad06SS's Avatar
I want to see the scan log showing your stock injector's being maxed out with your RIU kit Be patient, ther'll be some soon.
  #462
FAST06SS's Avatar
I knew 7K was a pipe dream from GM, since you said "more like 6800" and knowing the stock tach is in accurate, i'd say the rev limiter was untouched or maybe 200 rpm if at all. We need at least 7K+ with this powerband and gear spread to go anywhere. Oh well, back to waiting a couple more weeks for pcm access
  #463
NJBLUESS's Avatar
Look, I have to get home right now, I will be back in about 1.5 hrs. Will give as much info as I can.
  #464
GSoccer24's Avatar
this is frickin cool, you better not post until tomorrow because you were too tired of driving it around to test it out, that's what i'd do LOL
Old Apr 3, 2006 | 07:45 PM
  #465
retrop's Avatar
Originally Posted by zinner
Thats called abuse.
Honestly I don't care if you do burn outs and drag race whatever, but when you do that stuff and burn out the stock clutch it's not cause the clutch is crap it's because it's not intended for that purpose....
I think that if wheel hop wasn't a huge issue the clutch would be much longer life because you can mitigate wheel hop with slipping the clutch.
Exactly. Plus we all know with as bad as the wheel hop is in this car that it was not built as a drag car.....
Old Apr 3, 2006 | 07:46 PM
  #466
NJBLUESS's Avatar
I will watch it very close on the way home, it is very close to 7k, trust me.
Old Apr 3, 2006 | 07:47 PM
  #467
oh my Rev It Up kit is not on yet. and the stock GM injectors are never pushed to there limit stock
Old Apr 3, 2006 | 07:48 PM
  #468
gonzo's Avatar
I don't get wheel hop..... with stock mounts, but my clutch will slip, so now what is the explanation?????????????
Old Apr 3, 2006 | 07:49 PM
  #469
gonzo's Avatar
just make it home in one piece or atleast in good enough shape to type!!!
Old Apr 3, 2006 | 07:50 PM
  #470
iso's Avatar
iso
the reflash ups the rev limiter to 6750, so we get an extra 250 rpms.
Old Apr 3, 2006 | 07:51 PM
  #471
bhowman1980's Avatar
Does anyone know, Are the poly mounts helping with the wheel hop, that would deffinatly help with wear and tear on our cars regarless of driving styles. Sertainly would make it easyier to feather so clutch wear would be reduced.
Old Apr 3, 2006 | 07:53 PM
  #472
retrop's Avatar
Couldn't tell you. But i don't think you can blame the clutch. This is my first manual, i have over 10K miles and i do screw up shifting every now and then and my clutch is fine. I have launched my car maybe 3 times and never powershifted as i know at least a few people on here do. So unless you are doing something very rough to that clutch you may just have truly gotten a bad clutch.
BTW, yes i do drive my car hard, once i know i have traction in first.
Old Apr 3, 2006 | 07:54 PM
  #473
mken's Avatar
Considering my rpm gauge shows 6300 rpm every time I've hit the limiter, then if his is behind like mine he'd show 6800 when he's actually running 7000. Sounds about right to me...
Old Apr 3, 2006 | 07:56 PM
  #474
retrop's Avatar
Proof??
Old Apr 3, 2006 | 07:57 PM
  #475
BCobaltSS's Avatar
What I want to know is how come I live in michigan and I can't order Stage 2 for my car at any dealership around where I live but I can order only stage 1 and someone from Canada can not onlycan get Stage2 but basically have it installed before anyone here in michigan. Does any one in Michigan in the MAcomb/ Oakland Area know where I can Order this. Sorry about the bitchin.
