View Poll Results: Those who have it. Which is better?
Stage 1 with smaller pulley
18
39.13%
stage 2
28
60.87%
Voters: 46. You may not vote on this poll
GM Stage 1/2 Thread: Merged
OMG!!! What a difference!!! I could not stop spinning the tires, It's wet out. This engine woke up, especially in the upper RPM. Cruising in second and punched it, through my and my passangers' heads back.
Took about 2 hrs to install, the hub was a very tight fit.
YES, the redline is right around 7k, more like 6800 on my tach.
Sorry, I didn't watch my boost gauge, will do on the way home.
NO kidding??!!! So, it's true, 7K redline! I hope this is true, and not that it went to 7K only because you're spinning......
LSX RWD S/C conversion
Originally Posted by Bad06SS
Geez! How far are you driving? It should've only taken 10 min.!!! We're excited here!
Originally Posted by zinner
Thats called abuse.
Honestly I don't care if you do burn outs and drag race whatever, but when you do that stuff and burn out the stock clutch it's not cause the clutch is crap it's because it's not intended for that purpose....
I think that if wheel hop wasn't a huge issue the clutch would be much longer life because you can mitigate wheel hop with slipping the clutch.
Exactly. Plus we all know with as bad as the wheel hop is in this car that it was not built as a drag car.....
Originally Posted by FAST06SS
I knew 7K was a pipe dream from GM, since you said "more like 6800" and knowing the stock tach is in accurate, i'd say the rev limiter was untouched or maybe 200 rpm if at all.
We need at least 7K+ with this powerband and gear spread to go anywhere. Oh well, back to waiting a couple more weeks for pcm access
Originally Posted by gonzo
I don't get wheel hop..... with stock mounts, but my clutch will slip, so now what is the explanation?????????????
Couldn't tell you. But i don't think you can blame the clutch. This is my first manual, i have over 10K miles and i do screw up shifting every now and then and my clutch is fine. I have launched my car maybe 3 times and never powershifted as i know at least a few people on here do. So unless you are doing something very rough to that clutch you may just have truly gotten a bad clutch.
BTW, yes i do drive my car hard, once i know i have traction in first.
What I want to know is how come I live in michigan and I can't order Stage 2 for my car at any dealership around where I live but I can order only stage 1 and someone from Canada can not onlycan get Stage2 but basically have it installed before anyone here in michigan. Does any one in Michigan in the MAcomb/ Oakland Area know where I can Order this. Sorry about the bitchin.
