View Poll Results: Those who have it. Which is better?
Stage 1 with smaller pulley
18
39.13%
stage 2
28
60.87%
Voters: 46. You may not vote on this poll
GM Stage 1/2 Thread: Merged
Old Apr 9, 2006 | 07:44 AM
  #1251
280Z1977's Avatar
Originally Posted by RonSS
You play with Quad 442's and big blocks?
What are you....nuts?
Ha!
How's it going Doc?
I'll want to know how the stage 2 goes for you.
I'm going to do it too, but now I really wonder if my dealer could even come close to getting it done correctly. And you know why I say that......
Ron
Are you two twins??? You both have a big block powered car, quad 442, and SS/SC and then the kicker, you both live in the Northwest. Scary. Doc this is who I thought you were on .com.
Old Apr 9, 2006 | 08:40 AM
  #1252
RonSS's Avatar
Nope, not twins. Just a couple of old car guys.
I still have my Quad 442 though. Although I seldom drive it. The SS/SC has spoiled me.
Ron
Old Apr 9, 2006 | 10:59 AM
  #1253
Nauticabri's Avatar
Originally Posted by WopOnTour
Well the problem is (and ESPECIALLY the larger dealers) they will have BOTH! What gets used at the time is what matters. The local version of TIS generally runs faster and is quite new so some techs just do what they have been sucessful doing for years (stand-alone TIS) Some workstations in the shop might not be configured for TIS2WEB as it requires JAVA, Internet Explorer 6 and either Windows 2000 or XP. SOme of the shop workstations might still be Windows 98!!
WopOnTour
I'd be really pissed if I went in to get my stage 2 kit installed at my dealer and they did it for me, chargerd me and didn't do the reflash and never told me and made me find out on my own. Thanks for the GREAT info, so it's recommend for me to ask my dealership b4 I bring it in on tuesday fo rmy install and give them the heads up that it can only be done with tiss-2-web, and ensure they have it?
Old Apr 9, 2006 | 11:14 AM
  #1254
ChicagoSS/SC's Avatar
How may people have installed the GM stage 2 kits so far?
I am looking to do the install, but I really do not trust some of these local dealerships to do the job becasue there are not enough SS/SC on the roads for the dealerships to work on. Especially where I am. I will probably drive to Indy where I trust the dealerships more.
For me, I am waiting unil the dealerships have done acouple before I hand my car over. GM should have really given more direction to the dealships which the install of these kits. Cheers.
Old Apr 9, 2006 | 12:56 PM
  #1255
max_boost's Avatar
Originally Posted by AlphaJaguar5
6500 redline...
You really should READ the thread that the dyno chart came from. He even says that it is a dyno with the STAGE 2 kit on the car.
Originally Posted by redline
He didn't change the wording on the graph.. The top run was a base line--but not the highest one.---look at the dates. The bottom three are the stage-2 with the best one being first(bottom) I should have made him hit the rev limiter but didn't see any need with the tq falling off
http://tinyurl.com/pydcp
Old Apr 9, 2006 | 01:01 PM
  #1256
max_boost's Avatar
This has happened actually. You'll immediately know if it's happened to YOU if you dont have the higher 7000 fuel cut.
The dealer was having a hard time flashing my car since it was the first one they did so I was kind of concerned that they might not have gotten it right. So the first thing I did was made sure buy running it up to 7000, just to make sure.
Old Apr 9, 2006 | 01:56 PM
  #1257
JCswoosher2's Avatar
So is there still only 1 dyno done with stage 1 or 2?
Old Apr 9, 2006 | 02:00 PM
  #1258
max_boost's Avatar
I've only seen two and both of them are screwed up so.... I guess no real numbers yet.
Old Apr 9, 2006 | 09:44 PM
  #1259
Is there any sense in getting stage 2 and a 2.8 pulley or does it make more sense to get stage 1 and 2.8
Old Apr 9, 2006 | 09:51 PM
  #1260
max_boost's Avatar
There is no reason to get the Stage 2 if you are going to be getting your own pulley. The only thing Stage 2 adds is the 77.9 mm pulley and a shorter belt. Just get the stage 1.
Old Apr 9, 2006 | 11:16 PM
  #1261
zinner's Avatar
Moderator Alumni
Welp.
At 64 Pages I think we can put this to bed.
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
