View Poll Results: Those who have it. Which is better?
Stage 1 with smaller pulley
18
39.13%
stage 2
28
60.87%
Voters: 46. You may not vote on this poll
GM Stage 1/2 Thread: Merged
Higher rev's scare me personally! I am in pretty good with a local tuner here in slc that has been in some magazines and even on the show pinks. He has told me not to get the stage 2 kit for one reason. The reflash is just that, a reflash! It doesn nothing for being able to tune. Wait for some programmers to make some **** for our ECU and then have someone tune it with the intense kit and gm's belt and you will be much more impressed with your gains. Hell, you have already waited this long whats another couple of months?
Originally Posted by Brian MP5T
Yeah, that's why Top Fuel Drag Cars aren't tuned on a Dyno... Cause they don't mean anything..
LSX RWD S/C conversion
It is insane how much more horse you can gain from having your car tuned by someone who knows what they are doing. We just need to get into our ecu...........
Thing about the dynos, is first they are in an ideal controlled environment. They cannot measure the effects on H/P of things like CAI or Ram Air. They can also be very fickle. To compare two sessions, one prior to mods, one after mods, everything, and I mean everything must be equal or the results will be skewered. I had the Olds 455 in my drag car, (now 468 C/I), dynoed a while back and the H/P was way down. Turned out the dyno had a dirty filter. Then the MSD ignition control the dyno was using was malfunctioning. Then we discovered that the throttle was not opening up all the way. Granted this was an old school big block, but you get the idea of just a few of the types of things that can go wrong in the dyno room. If you use RPM for the first test session, you should use RPM for the next test session. My dynoing was done on an engine dyno. When you use a chassis dyno, other variables may come in to play. You have to consider the parasitic loses also. It is just too early to judge the Stage kits. Personally, I have a Stage II on the way, and it is going in as soon as I get it. I have no doubt that it will provide a decent power increase. To get a comparable H/P increase with the old school stuff involved a lot more work and a lot more money. Just to get the H/P that GM claims for the Stage II with mere bolt-on's, reflash, is the cheapest H/P you'll ever make. If you consider that, from all I have read, GM underrated the H/P of the 2.0 S/C by somewhere around 40 engine H/P, depending upon the results you consider determined by different tests. I would wager that if anything, GM was likely conservative when rating the Stage II increase as well.
I can tell you this. My little 2006 Sunburst Orange Metallic SS S/C is one honkin' little scooter the way it is. The Stage II will wake it up even more.
Bye the bye, I don't think any thread isn't worthwhile. If you learn one thing you didn't know before, which may be buried deeply in the thread, it was worth it. For example, it is my understanding there is a Stage III currently under development. It is classified off road, and will be wicked, with some slick features. That's all I can say for now about it without jeapordizing folks. Probably said too much as it is. Just know it is in the works. Who knows if it will ever reach us, or when.
Doc
Originally Posted by cobss187
im tellin you..... what i think probably happened is that the idiots at chevy prob didnt do the reflash and just threw the mods on there... ********
What appears to be happening is some dealers are using a "stand-alone" installation of TIS (the software used in combination with the TECH2 scan tool to reflash your car)
The stand-alone version DOES NOT (at this time) contain the Stage flash files, so when they go to use the VCI number provided by Techline phone support (as outlined in the Stage kit instructions) TIS cant find the correct software and gives a "VCI not found" error, and defaults to the "normal" software screens. The tech THINKS all is well, and burns it up.
When you book you car in you might want to confirm that the dealer is using TIS2WEB which is the "live on-line" version of TIS, not the stand-alone version.Visually it's easy to identify as the graphics are quite a bit different during the reflash (see below) CURRENTLY this method is the only way to get Stage kit software, although it will likely appear in future stand-alone installations as well (maybe in a month or two)
HTH
WopOnTour
V V V TIS2WEB vs. TIS (stand-alone) V V V
Originally Posted by WopOnTour
This has happened actually. You'll immediately know if it's happened to YOU if you dont have the higher 7000 fuel cut.
When you book you car in you might want to confirm that the dealer is using TIS2WEB which is the "live on-line" version of TIS, not the stand-alone version.Visually it's easy to identify as the grpahics are quite a bit different during the reflash (see below) CURRENTLY this method is the only way to get Stage kit software, although it will likely appear in future stand-alone installations as well (maybe in a month or two)
HTH
WopOnTour
V V V TIS2WEB V V V vs. V V V TIS (stand-alone) V V V
HTH
WopOnTour
but why would the tech think all is well if the screen says "VCI not found". That would throw up a red flag if it were me?
Very good information
HTH
WopOnTour
HTH
WopOnTour
Thank you so much. This could very well help me avoid any potential problems or hassles when I get my Stage II installed.
Doc
Originally Posted by TheToolmaker
I am still confused how you got your numbers. You say the guy went off of wheel speed. In that case, the car would not be making full power. My car is alot faster in every gear. I saw the Tech2 post the other day and the guy hit 36 mph in first, so if I am understanding this all correctly he stopped way short of redline on your dyno too.
PLEASE CORRECT ME IF I AM WRONG!
I talked to a couple of tuners and they said that wheel size, gear ratio and wheel speed were all needed to make this type of calculation. The tech did not enter wheel size nor gear ratios. He screwed me out of $100. basically. I tried to get on another dyno today but no luck. Everyone do like me ignore my dyno sheet and wait for others to post theirs. I do not trust or beleive the numbers I got yesterday. Neither does my wife and I quote her " I notice the difference, your car has more of what I don't like. Fast"
HTH
WopOnTour
HTH
WopOnTour
Thanks. So when I go for my install of my Stage 2 on Thursday do I just ask the the Service Advisor? It's a big dealership so I would imagine they have the online version. West Herr Chevrolet of Hamburg (NY) and they also have a West Herr Chevrolet of Orchard Park (NY) and they have about 8 other dealerships but obviously different car manufactures
HTH
WopOnTour
HTH
WopOnTour
HTH
WopOnTour
HTH
WopOnTour
WopOnTour
Originally Posted by ballerSS
Thanks for the info WOP! Just so I can look like I know what I'm talking about... how is this pronouced? Is it Tiss-2WEB or T-I-S-2WEB?
pronounced tiss-two-web
Good Luck!
Wop
Originally Posted by distillion
so i go in with my stage 2 and tell the stealership, i have stage 2, i need the stage 2 flash and make sure program is TIS2WEB, correct?
HTH
WOT
Originally Posted by clownhair
you need to calm down, get some of that suppressed anger out. Almost everything you post is very abrasive.
Except this smiley that I used.. ...
I'm just saying that the Dyno results should not be ruled out just because you don't like the results..
Originally Posted by mrdoc442
Thanks for the welcome 280Z1977. My commitment to you is I will do my best to honestly share a little of my 30+ years of NHRA, AHRA competitive drag racing expertise and philosophies. I cut my computer controlled engine racing teeth on a modified 1987 Buick Grand National, a modified 1992 GMC Typhoon and a 1991 GMC Syclone, as well as a 1991 Oldsmobile Calais Quad 442 w/minor mods - most similar to the Cobalt FWD. I try to avoid being drawn into pissing matches, endeavor to treat folks with dignity and respect, and any suggestions I make you can pretty well bank on. I was fortunate to be very successful in my racing efforts, and I'm not finished yet. I'd appreciate being held harmless for occasional misspellings, as I suffer from occasional "fat finger syndrome", and an occasional brain fade.
Doc
Doc
What are you....nuts?
Ha!
How's it going Doc?
I'll want to know how the stage 2 goes for you.
I'm going to do it too, but now I really wonder if my dealer could even come close to getting it done correctly. And you know why I say that......
Ron
That is CORRECT! How's it running for ya so far Nin??
Wop
Wop
