GM Stage 3
By the way, i'm not sure if the 2.6" pulley is correct, that was more of a guess since we were told the size in mm at the time. I don't know the exact size for the pulley, but i do know for sure that each stage kit is made to produce about 2 psi more with the smaller pulleys.
So, in turn, the stage two should produce about 14.5 psi (max average) and the stage 3 with the smaller pulley should produce about 16.5 psi (max average, based on the fact that most cars run stock about 12.5 psi max).
While i was in the stage 3 car i didn't really watch the boost gauge though, i kinda got distracted with the nitrous. I actaully drove it a little and it definitely felt stronger than stage 2 without using nitrous, it was just a shame whenever i would try a hard 1st-2nd shift that the shifter knob would pop off
. Damn the guy who jury rigged it
Oh yeah, i don't know if Zenkat mentioned this but he was running stock everything even the airbox, only change was a missing catalytic converter.
.Oh yeah, i don't know if Zenkat mentioned this but he was running stock everything even the airbox, only change was a missing catalytic converter.
Originally Posted by Formula96
What is there to hate about nitrous, if you are in a race and need just that little bit more, then push the button....
cause i wouldn't just push the button, i would hold it down until my motor melted the engine mounts and fell through the blacktop
I'm still not sure about all this...If infact a smaller pully is involved that means either a new tensionor or even smaller belt again...which doesnt really make it a weekend put in/pull out...Trust me, it would be great to see a GM Stage 3 kit but I dont believe its going to include nitrous, If GM warrentys their stage kits I highly doubt they would start marketing a kit that is going to run that close to the limits...If so they are gonna be paying out the ass for every break down imaginable due to people not knowing what they are doing. Just my thoughts on the whole deal. Im not saying there wont be a GM Stage 3 kit but I highly doubt it will involve nitrous once it gets here...
ford did a similar thing with their saleen N20 Focus.. it was way weird and everything came under warantee... didnt come with a bottle and as soon as you put the bottle in... you voided your warantee..
Dude, WRONG. It wasn't Ford's Saleen N2O Focus. It was all Saleen. It did come with a bottle, But there was just a few pieces of wiring left out. IF YOU WIRED IT IN, Then it voided your warantee. That and it was a stupid idea from the start. Body kit+Nitrous+Steve Saleen's name=Saleen Rice!
Edit: Not trying to be an ass, Just kinda am one.
Originally Posted by Zenkat
True, i dont really like nitrous either. But the fact the box is set up to handle it well, is just a nice touch.
the nice thing about this box is the fact that when i run my NOS...and i will i can activate this box and it'll scale the the fuel to make up for the N2o....good ****!
Originally Posted by dirtySSout
Stage 3 Would Be Cool If It Was A Replacement S/c (screw-type Would Be Nice) That Pumps More Cfm At The Same Boost Levels! Sort Of Like Mopar Does With The Td04 Turbo(stock) To A Td05 Turbo(stage 3)!
Also, i forgot to mention that the smaller drive belt that comes with the stage 2 is also used for the stage 3 pulley, so it can't be that dramatic of a size change cause there are no slipping problems.
Originally Posted by mattyfinch
its supposed to make 344 hp and 317 torque from the numbers ive seen
