gm stage 3 kit
Old Sep 19, 2007 | 06:54 PM
quickspec's Avatar
gm stage 3 kit
I just put my gm stage 3 pcm and 2.9'' pulley back on the car, but now when I slowly accelerate the car is jerky, and when I full out floor it, it's fine. What could this be caused from, I put new plugs in and gapped them to 40, and also the stage 3 pcm is suppose to reset the oil life when installed, but it never did, is that good or bad? I also have aem intake, and catback.
bump, anybody?
Old Sep 19, 2007 | 07:01 PM
Woodyr007's Avatar
I dunno man, you sure you put the right pcm in I know stupid question
Old Sep 19, 2007 | 07:08 PM
quickspec's Avatar
Don't worry man I thought the same thing too, I pulled it back out and checked it, it was the stage pcm. How do you know if one of your injectors is going bad?
Old Sep 19, 2007 | 07:13 PM
Woodyr007's Avatar
Ehh couldnt tell you
Off-topic how do you like the stg 3? I have a zex kit do you know if that will work with it? I have been pondering going that route
Old Sep 19, 2007 | 07:17 PM
07cobaltss's Avatar
sounds like a TPS sensor going bad to me... could be the MAF to. i've seen both with those simptoms.
Old Sep 19, 2007 | 08:49 PM
quickspec's Avatar
Man I love it, when I had it installed before it was awesome, road smooth then, I was thinking of getting the zex kit, but it says its only for a 50 dry shot, not a 55 dry like the zex, so im not sure.
Thanks for the advice.
I'm going to go by some maf cleaner tomorrow and try that, see if that helps.
Old Sep 20, 2007 | 12:24 AM
StealthSS's Avatar
what do u mean exactly by jerky, because im not staged at all and i get the hiccup effect sometimes at slow speeds.
Old Sep 20, 2007 | 08:03 AM
Acidangel_5.0's Avatar
will feel like a dropped cylinder...
as far as the rest of your question goes....
you might be feeling some belt slippage... i run a 2.9 also and i can tell there is some slippage down low every now and then but not much.. it will give the car that little "hiccup" feel while accelerating.. but nothing extremely noticable.. just feels like your power comes on in stages instead of linear..
Old Sep 20, 2007 | 08:11 AM
SKDR112888's Avatar
car used to do that when it was running super rich becuase Doc tuned it for 42#s injectors when I had 60s, so you only imagine.....
Old Sep 20, 2007 | 08:28 AM
AmericanSS's Avatar
I heard that GM has a new Reflash for our ECU's that are not staged to get rid of those hickups
Old Sep 20, 2007 | 09:31 AM
quickspec's Avatar
I'm also running a stage 2 belt, do you think it could still be slipping?
Old Sep 20, 2007 | 10:29 AM
red ss s/c's Avatar
i also have the stage 3,never had a problem with the belt.my problem after install was clutch it was slipping like hell
Old Sep 20, 2007 | 10:41 AM
look at the belt.. you will be able to tell if it slips.. look for odd wear patterns or anytype of odd looking rivits/cuts
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 28, 2015 12:51 PM
