GM Stage 3 + trifecta w/ac and adjustable launch control!
Very interested in learning a bit more about this, when I did 80s in HPT they did not idle very well for me at all. My 60s are a bit better but still dont run as good as the stock or the gm stage 2 injectors did. Would this run those better? I use HPT so obviously I would want to continue to be able to do that. This launch control, I don't know much about it, how is it activated and used?
you can adjust it when you are in ACC mode. all you have to do is push the gas. and to activate it you have the car on and must be at a stop then push the gas and there she goes!
