Got a new toy today
Old Jul 17, 2007 | 10:17 PM
ptrblkz24's Avatar
Got a new toy today
Super 20g turbo!!!
Im still waiting on the manifold,and i have to order a bov.I havent decided which one i want yet though.Me and my friend are working on fabbing a throttle body adapter,and i have to get a pulley to replace the s/c.This thing is gonna be a beast when its done.
Old Jul 17, 2007 | 10:20 PM
06CobaltssOrange's Avatar
got to love new toys there amazing keep us posted on the work!
Old Jul 17, 2007 | 10:22 PM
06blackSC's Avatar
so why is the valve for the wastegate welded shut? do you plan on using an external gate and is your turbo manifold prepped for it?
Old Jul 17, 2007 | 10:31 PM
ptrblkz24's Avatar
The valve for the wastegate is inside the housing.Im not sure why the peice is welded shut.Even if it was not welded shut,it has 3 bolts that hold the flange on.Theres no way it would seal properly with 3 bolts,so i guess its closed for a reason.Maybe the turbo experts can chime in,cause im far from one,lol.
This is the exhaust flange im gonna need.
Old Jul 18, 2007 | 01:12 AM
noturtypicalone's Avatar
those turbo's are set up internally gated. if you weld it shut like that it's to run an external gate. its normal
Old Jul 18, 2007 | 01:39 AM
ReMz's Avatar
mmmmmmmmm
Old Jul 18, 2007 | 02:25 AM
Jmc007's Avatar
Where do you bought your turbo manifold ?
Old Jul 18, 2007 | 10:08 AM
Sw4y1313's Avatar
make sure your manifold is setup for an external gate. If not your gonna have to spend a little extra to get it prepped for one. GL on the build. Cant wait to see the results.
Old Jul 18, 2007 | 12:45 PM
Area47's Avatar
Rent me! per hour
it plays into the scavenge effect. it's not 100% closed off, id say maybe 5% if that.
Old Jul 18, 2007 | 07:02 PM
ptrblkz24's Avatar
I got the manifold from ebay.
I dont need a manifold with an external wastegate.This turbo has an internal wastegate.
No,im pretty sure its blocked off completely.If it wasnt sealed,youd have an exhaust leak.It seems like its some sort of expansion plug,and they put a couple of spot welds on it to keep it from popping out.
Old Jul 18, 2007 | 07:23 PM
Area47's Avatar
Rent me! per hour
poke your finger on the inside of the exhaust housing near the compressor wheel.
there is a hole in there for the exhaust to flow out of the wastegate side.
i said the 5% due to the hole being closed off. like in your typical mhi set ups.
Old Jul 18, 2007 | 07:32 PM
ptrblkz24's Avatar
Oh ok,i thought you were talking about the plug with the weld spots on it.
Old Jul 18, 2007 | 07:35 PM
Area47's Avatar
Rent me! per hour
nope!
the super 20 was a old school upgrade turbo for the 2.2-2.5 turbo dodge stuff
much like a super 60, so on and so forth.
Old Jul 18, 2007 | 07:38 PM
ptrblkz24's Avatar
nope!
The super 20 is still a pretty popular upgrade.Alot of srt4's and evos upgrade to these.
articzap's Avatar
Yet the internal gate is welded shut......
Old Jul 18, 2007 | 07:41 PM
ptrblkz24's Avatar
No,the gate is inside the exhaust housing next to the compressor wheel.
Old Jul 18, 2007 | 07:54 PM
06blackSC's Avatar
dude, that gate is welded shut. the part you are refering to is that big gold looking actuator outside of the turbo. If your turbo was internally gated, then where does the exhaust dump from the gate go? especially if you have that little addaptor ring in there?
not trying to be fresh, we would just hate to see you hook that thing up and find out you have no wastegate at all.
Old Jul 18, 2007 | 08:02 PM
blktrax's Avatar
What hes saying is there should be a hole inside the exhaust port other than the hole for the exhaust blades of the turbine, if there is a hole in there you're good, if not you got a problem. If not thats a RACE version turbo thats set up to be spun continously and RELILES solely on a BOV, risky but would work. My 85 Lebaron Turbo knew so. also saves form haing to fab up a funky exhaust "manifold" to make it work, just weld up a standard flange like pictured before and go, internaly wastegated and roll.
I understand what what you both are saying just trying to bridge the gap
Old Jul 18, 2007 | 08:06 PM
ptrblkz24's Avatar
Nah man,the gates inside
Old Jul 18, 2007 | 08:10 PM
articzap's Avatar
Horribly inefficient design.
Old Jul 18, 2007 | 08:16 PM
Moza13-'s Avatar
yea the super 20 is inefficient....thats why so many cars use them, because they suck so bad.
Old Jul 18, 2007 | 08:21 PM
blktrax's Avatar
So what else are you doing to the motor other than mounting it up?
Internals of any kind?
Old Jul 18, 2007 | 08:30 PM
articzap's Avatar
To bad you fail to see what I'm talking about. The internal gate design. Thats a place for exhaust gases to get trapped those causing back pressure after the turbo holding back power.
06blackSC's Avatar
i retract my previous statements. good luck with the build!
Old Jul 18, 2007 | 09:23 PM
95cam86roc's Avatar
Looks good, what did one of those set you back?
