got tuned friday!
Old Jan 17, 2008 | 11:17 AM
  #251
memphisr24's Avatar
Originally Posted by Area47
just an fyi for people thinking of pushing the afr limit higher. you lose power after 12.5.
i can't say how i know this, but i do.
Agreed I know a little something about that as well
Old Jan 17, 2008 | 11:20 AM
  #252
Area47's Avatar
Rent me! per hour
yea. i found out the hard way
whoopsies!
13.5 afr does not equal more power than 11.6
Old Jan 17, 2008 | 11:23 AM
  #253
2K5SS/SC?'s Avatar
Originally Posted by Edubs
They're actually not bad cams. They definately don't give the power that the HKS grinds will, but overall, they make great power under the curve compared to similar modded cobalts on Matt's dyno. When I finally get back and get new numbers, I'll see if I can get my dyno chart and another 2.8" pullied car's dyno chart to compare from Matt.
I'm sure when all is said and done, you'll be pushin' well into the 320's w/ Meth. I believed your numbers from day one!
Nice, I can't wait to see what differences are. I might try a head porting with the supertech springs, balance shafts, and 272 HKS grind cams when I return from the desert, but I have some house projects to do first when I get back. Please keep me posted on the results as I have a sparked interest in cams right now.
Old Jan 17, 2008 | 11:30 AM
  #254
Edubs's Avatar
If I had to do it all over again, that's exactly what I would have done. I'll let you know as soon as we finish up. Hopefully we can get down there in the next couple of weeks.
Old Jan 17, 2008 | 12:50 PM
  #255
SSdan's Avatar
Soon Erik you can't use my graph to match.
Some secrets coming in the next 2 months.
Old Jan 17, 2008 | 01:04 PM
  #256
Edubs's Avatar
I guess I'll have to coherce that outta Matt when I talk to him next...
Old Jan 17, 2008 | 01:05 PM
  #257
SSdan's Avatar
I'm shooting for 265 on his..And with what I plan and only being 20whp off right now, it seems very plausible.
  #258
Edubs's Avatar
And I love how we just completely took over this kids thread and turned it into our own ***** thread.
Old Jan 17, 2008 | 01:06 PM
  #259
redlineblueline's Avatar
well thats because hes a water head
Old Jan 17, 2008 | 01:07 PM
  #260
Edubs's Avatar
Well I'm shooting for 268, that's 300 flat
Old Jan 17, 2008 | 01:08 PM
  #261
SSdan's Avatar
I don't see how we WON'T hit that, we really aren't far from it at all.
Old Jan 17, 2008 | 01:11 PM
  #262
Edubs's Avatar
Especially considering that I plan to dyno when it's in the 40's w/ low humidity. It's not an unbelievable goal, just a tall order, for me at least. The TriFlow cams don't really seem to add tons of peak hp, just a good amount under the curve...
  #263
i like the fact you all are getting up on 300hp with above a 2.5
Old Jan 17, 2008 | 02:39 PM
  #264
M-Dub's Avatar
WE TOOOK THIS SUMBICH OVER!
I want to hit 270s and I'll be good with that. And I'm sure with Area's help along with changing a thing or 2 it'll happen.
And I not only see Area hitting 300whp he will DESTROY 300 whp!
Old Jan 17, 2008 | 02:55 PM
  #265
SSdan's Avatar
He's my hero.
Old Jan 17, 2008 | 02:59 PM
  #266
Edubs's Avatar
Trust me, you'll want more!
Old Jan 17, 2008 | 03:03 PM
  #267
M-Dub's Avatar
I'm sure.... but come April I am moving to NC... and I won't have Area like 5 minutes from me anymore!
Which makes me sad.... so I will want it safe.
  #268
06black's Avatar
let me guess, with the cams you saw more boost huh.....
god the tri-flows are horrid.
sorry to tell you all this so bluntly.
not knockin you, just that cam
Old Jan 17, 2008 | 03:09 PM
  #269
Edubs's Avatar
Actually, on the 2.79", I see about 16.5psi of boost when the temperature is normal (i.e. - 40-80*F). Most people on the 2.79" see 17.5psi, so I'd say I lost a pound, which is what I wanted...
Old Jan 17, 2008 | 03:12 PM
  #270
06black's Avatar
our boost gauge isnt reliable for ****, check it with HPT against a vary similar car or your car pre-cams i think you'll be surprised.
the theory behind the "tri-flow" is nice indeed but there are massive reports of people getting the tri-flows in GB's and such, then the idiots rant and rave about gaining boost or at least staying vary close to pre-cam....
that tells me one thing, totally useless cam.
agreed?....yup.....ok.
Old Jan 17, 2008 | 03:13 PM
  #271
Area47's Avatar
Rent me! per hour
hehehehhe. now you see why i didn't order those
anyways. im a hero? um, thanks? send wimmenz
im not sure about destroying 300. im just aiming to get close without over spinning the blower like i am now by 667rpms
{did the math, i was bored}
Old Jan 17, 2008 | 03:14 PM
  #272
06black's Avatar
thanks for PMing me back on RLF bryan......
  #273
Edubs's Avatar
I'll keep an eye out for that when we throw it back on the dyno.
Old Jan 17, 2008 | 03:16 PM
  #274
Area47's Avatar
Rent me! per hour
ps. have the lsa of the cams widened up to 112-114 degree's. boost will go down. cylinder pressure will go up
i did *******!
Old Jan 17, 2008 | 03:26 PM
  #275
06black's Avatar
i did *******!
cylinder pressure = mad powa!!!
PMd back cracka!
