H/E Quick Question
Old Mar 12, 2012 | 12:40 PM
SlowCobaltSS's Avatar
H/E Quick Question
Whats the plumbing on the zzp s2
Correct me if im wrong
Im leaving the stock heat exchanger in there
So I remove the hose thats on the driver side of the stock h/e that runs to the ie pump and run that to the bottom fitting on the zzp s2 and now run the top fitting hose on the s2 to the ic pump where I removed the hose that went to the stock h/e
On the side note Im not installing a zzp s2 right now Im actually removing one because it got bent and Im going to get it repaired so im making sure that when I remove it and run the hoses i dont screw up the coolant route because when it got installed there was other hoses that needed to be removed around.
Old Mar 12, 2012 | 01:07 PM
Staged07SS's Avatar
Administrator
Administrator
http://www.zzperformance.com/miscftp/HE%20routing1.jpg
Old Mar 12, 2012 | 01:14 PM
keiserX13's Avatar
Old Mar 12, 2012 | 01:19 PM
Okay cool thanks, So i was correct all i need to do is remove the hose that runs from my stock h/e on the driver side to the s2 and run a hose from there back to the pump.
Old Mar 12, 2012 | 01:20 PM
Staged07SS's Avatar
Administrator
Administrator
I posted the same thing
Yes.
Old Mar 12, 2012 | 01:25 PM
Cool, I will be pulling it out today.
Now here's the main thing im wondering about
Im running a 2.8pulley and 60lbs injectors with 16* advanced timing is this going to do any damage with just running a stock little heat exchanger.
Old Mar 12, 2012 | 01:30 PM
Staged07SS's Avatar
Administrator
Administrator
No. Just don't beat on it, and you will be fine.
Old Mar 12, 2012 | 01:32 PM
Ok Thanks bro
Old Mar 12, 2012 | 06:15 PM
keiserX13's Avatar
i know
but i embedded it
Old Mar 13, 2012 | 07:23 AM
Staged07SS's Avatar
Administrator
Administrator
i know
but i embedded it
blah blah blah
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
