had coolant flushed.
Old May 7, 2009 | 04:31 PM
RednBlack's Avatar
had my engine coolant flushed replaced with green coolant. My questions is since we have two different coolant systems they did not flush the sc coolant system and left the dexcool. could running two different coolants affect the car? I am buying a heat exchanger at the end of the month and will switch it over to green to jus want to make sure I will be ok for now.
Old May 7, 2009 | 04:40 PM
Cefaln452's Avatar
your fucked... most likley its not dexicool
Old May 7, 2009 | 04:52 PM
rnjmur's Avatar
Doesn't matter, the two systems are seperate.
Old May 7, 2009 | 04:55 PM
1niceLS's Avatar
x2! needs to be red
Old May 7, 2009 | 04:57 PM
Maven's Avatar
youre fine, they are seperate, and even if they werent YOU CAN MIX Dex and regular coolant, its just that its no longer rated for 5y/100k miles anymore. Green coolant is a 2yr/24mile affair.
Old May 7, 2009 | 05:05 PM
RednBlack's Avatar
Originally Posted by 1niceLS
x2! needs to be red
im not sure im tracking? The sc coolant is a redish orange so im sure its dexcool and thanks for the quick responses guys!
Old May 7, 2009 | 05:08 PM
ShortStack's Avatar
They are different systems. AS maven said, your fine.
Old May 7, 2009 | 05:09 PM
RednBlack's Avatar
sounds good to me thanks!
brandon04
Oct 21, 2015 07:04 AM
vjoel2011
Oct 2, 2015 12:11 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
ATOMbomb
Sep 11, 2015 10:48 AM
